ASUS Eee PC 1008ha Battery Replacement
Views: 11K
View statistics:
Past 24 Hours:
11
Past 7 Days:
35
Past 30 Days:
100
All Time:
11,287
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This operation would be done if the battery fried or stopped functioning. You will be carefully removing the keyboard, locating the battery, and replacing it as you please.
Tools
    1. ASUS Eee PC 1008ha Battery Replacement, Battery: step 1, image 1 of 1
      • Using the plastic opening tool, carefully pry the top panel from the base.
      Ask FixBot
    2. ASUS Eee PC 1008ha Battery Replacement: step 2, image 1 of 3 ASUS Eee PC 1008ha Battery Replacement: step 2, image 2 of 3 ASUS Eee PC 1008ha Battery Replacement: step 2, image 3 of 3
      • Lift the side of the keyboard.
      • Disconnect the attached ribbon located underneath the keyboard.
      • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
      Ask FixBot
    3. ASUS Eee PC 1008ha Battery Replacement: step 3, image 1 of 2 ASUS Eee PC 1008ha Battery Replacement: step 3, image 2 of 2
      • Use your fingers to lift the battery and gently disconnect the wires from the base.
      Ask FixBot
Alex Powers
101 Reputation
2 Guides authored
Cal Poly, Team 21-52, Johann Spring 2013 Member of Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Members
72 Guides authored
4 Guide Comments
where could i find compatible batteries?
qforkyu - Reply Share
Good question! Did you find one?
paulteale - Reply Share
This guide is misleading. There is no way to do step 1 just from the front. At least I cannot do it and my notebook is already half open due to the swollen battery. Most guides show that you need to disassemble the whole thing.
For instance:
http://forum.notebookreview.com/asus/388...
cis - Reply Share
Батарея состоит из трёх отдельных Li-ion аккумуляторов, соединённых через плату контроллера. Обычно вздувается один из трёх аккумуляторов. Надо разобрать ваш нетбук, как показано в видео:
https://www.youtube.com/watch?v=-3ipeduI...
Тогда надо её аккуратно выкусить и стараться не проколоть надутую батарею, потому что в ней много неприятного запаха. На её место можно поставить подходящий по толщине аккумулятор с напряжением 3.6 - 3.7V с током до 1000mA (1A) и обязательно соблюдать полярность при установке аккумулятора. Тогда вам будет счастье.
С уважением, устный переводчик синхронист.
Simultaneous Translation - Reply Share
Past 24 Hours: 11
Past 7 Days: 35
Past 30 Days: 100
All Time: 11,287
