ASUS E210MA-TB.CL464BK Battery Replacement
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: step 1, image 1 of 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: step 1, image 2 of 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: step 1, image 3 of 3
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
    Ask FixBot
  2. ASUS E210MA-TB.CL464BK Battery Replacement: step 2, image 1 of 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
    Ask FixBot
  3. ASUS E210MA-TB.CL464BK Battery Replacement: step 3, image 1 of 2 ASUS E210MA-TB.CL464BK Battery Replacement: step 3, image 2 of 2
    • Remove the 4 mm screws around the USB port.
    Ask FixBot
  4. ASUS E210MA-TB.CL464BK Battery Replacement: step 4, image 1 of 2 ASUS E210MA-TB.CL464BK Battery Replacement: step 4, image 2 of 2
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
    Ask FixBot
  5. ASUS E210MA-TB.CL464BK Battery Replacement: step 5, image 1 of 2 ASUS E210MA-TB.CL464BK Battery Replacement: step 5, image 2 of 2
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
    Ask FixBot
  6. ASUS E210MA-TB.CL464BK Battery Replacement: step 6, image 1 of 1
    • Lift up and remove the battery.
    Ask FixBot
John Hutchins
763 Reputation
5 Guides authored
Gateway, Team 73-6, Gonzalez Spring 2023 Member of Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 78
All Time: 1,785
