Up to 20% off select tools
ASUS D550MA-DS01 Fan Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
83
All Time:
1,455
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If cooling has become an issue in your computer and your fan is not getting the job done, then it may be time to replace your fan. This guide will show you how to replace the fan in your laptop.
    1. ASUS D550MA-DS01 Fan Replacement, Keyboard Module: step 1, image 1 of 2 ASUS D550MA-DS01 Fan Replacement, Keyboard Module: step 1, image 2 of 2
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
      Ask FixBot
    2. ASUS D550MA-DS01 Fan Replacement: step 2, image 1 of 1
      • Turn the laptop over and open the display.
      • Insert the flat edge of the spudger into the crease of the keyboard cover.
      • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
      • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
      Ask FixBot
    3. ASUS D550MA-DS01 Fan Replacement: step 3, image 1 of 2 ASUS D550MA-DS01 Fan Replacement: step 3, image 2 of 2
      • Make sure that the entire cover has been released from the plastic clips.
      • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
      • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
      Ask FixBot
    4. ASUS D550MA-DS01 Fan Replacement: step 4, image 1 of 1
      • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
      • Disconnect the three data cables from the motherboard.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
      Ask FixBot
    5. ASUS D550MA-DS01 Fan Replacement: step 5, image 1 of 1
      • Remove the fully disconnected keyboard module from the laptop.
      Ask FixBot
    1. ASUS D550MA-DS01 Fan Replacement, Battery: step 6, image 1 of 2 ASUS D550MA-DS01 Fan Replacement, Battery: step 6, image 2 of 2
      • Do not use any metal tool to pry any type of battery. Doing so can puncture or short the battery, resulting in damage or injury.
      • Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
      Ask FixBot
    2. ASUS D550MA-DS01 Fan Replacement: step 7, image 1 of 2 ASUS D550MA-DS01 Fan Replacement: step 7, image 2 of 2
      • Lift the battery out and remove it:
      • The battery is connected to the motherboard on the left side.
      • Use your fingertips to evenly grip the battery on the left and right sides of the battery.
      • Pull straight up to lift the battery out of its place.
      • Do not use excessive force or attempt to pry the battery with any tools. Doing so will result in damage to the laptop.
      Ask FixBot
    1. ASUS D550MA-DS01 Fan Replacement, Hard Drive: step 8, image 1 of 2 ASUS D550MA-DS01 Fan Replacement, Hard Drive: step 8, image 2 of 2
      • Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
      • There are two screws connected to the motherboard and two screws connected directly to the case.
      Ask FixBot
    2. ASUS D550MA-DS01 Fan Replacement: step 9, image 1 of 1
      • Remove the hard drive by sliding it to the right to disconnect it from the motherboard and lifting out.
      • Be sure to fully disconnect the hard drive from the motherboard to ensure that you do not damage the connectors.
      • If necessary, unscrew the old hard drive from the holster and screw the new one into the holster.
      Ask FixBot
    1. ASUS D550MA-DS01 Fan Replacement, DVD Drive: step 10, image 1 of 2 ASUS D550MA-DS01 Fan Replacement, DVD Drive: step 10, image 2 of 2
      • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
      Ask FixBot
    2. ASUS D550MA-DS01 Fan Replacement: step 11, image 1 of 1
      • Slide the drive out to the right of the laptop to disconnect from the motherboard.
      • Lifting the drive straight out without sliding to the right will damage the motherboard.
      Ask FixBot
    1. ASUS D550MA-DS01 Fan Replacement, Motherboard: step 12, image 1 of 2 ASUS D550MA-DS01 Fan Replacement, Motherboard: step 12, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
      • While unscrewing the screws, it may be helpful to use the tweezers to keep control of the screws.
      Ask FixBot
    2. ASUS D550MA-DS01 Fan Replacement: step 13, image 1 of 3 ASUS D550MA-DS01 Fan Replacement: step 13, image 2 of 3 ASUS D550MA-DS01 Fan Replacement: step 13, image 3 of 3
      • Disconnect the three cables attached to the motherboard.
      • Do not pull the cables by their wires. This can lead to damage to the cables.
      • The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
      • There may be clear tape holding the screen connector in place.
      • The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
      Ask FixBot
    3. ASUS D550MA-DS01 Fan Replacement: step 14, image 1 of 1
      • Pull the motherboard to the right to clear the peripheral connections of the laptop casing.
      • Lift the motherboard out of the laptop.
      Ask FixBot
    1. ASUS D550MA-DS01 Fan Replacement, Wireless Network Card: step 15, image 1 of 3 ASUS D550MA-DS01 Fan Replacement, Wireless Network Card: step 15, image 2 of 3 ASUS D550MA-DS01 Fan Replacement, Wireless Network Card: step 15, image 3 of 3
      • Locate the Network Interface Card (NIC) on the motherboard.
      • Note the orientation of the white and black wires on your NIC. The may connection differ from the picture.
      • Gently disconnect the white and black wires by pulling it off of the NIC card. These wires should come off easy.
      • If you are following these steps for the prerequisite to remove the motherboard, you do not need to completely remove the NIC. Just remove the wires. The proceeding step can be skipped.
      Ask FixBot
    2. ASUS D550MA-DS01 Fan Replacement: step 16, image 1 of 2 ASUS D550MA-DS01 Fan Replacement: step 16, image 2 of 2
      • Remove the screws that are holding down the wireless network card with the Phillips #1 screwdriver.
      • After removing the screws, the NIC will lift up in a spring action.
      Ask FixBot
    3. ASUS D550MA-DS01 Fan Replacement: step 17, image 1 of 1
      • Gently pull out the NIC.
      • Do not use excessive force or wiggle the card out. The NIC should slide out easily.
      Ask FixBot
    1. ASUS D550MA-DS01 Fan Replacement, Fan: step 18, image 1 of 2 ASUS D550MA-DS01 Fan Replacement, Fan: step 18, image 2 of 2
      • Remove the two screws shown with the Philips #1 screwdriver.
      Ask FixBot
    2. ASUS D550MA-DS01 Fan Replacement: step 19, image 1 of 1
      • Carefully slide out fan.
      • The fan is difficult to maneuver out. Carefully wiggle the fan towards you before attempting to lift it out.
      • If you attempt to lift the fan before freeing it from the speaker housing, it will get stuck. In this case, push the fan back into its place and try again.
      Ask FixBot
Author
with
Calvin Wieczorek
413 Reputation
3 Guides authored
IUPUI, Team 1-2, Baechle Fall 2015 Member of IUPUI, Team 1-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G2
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 83
All Time: 1,455
