Up to 20% off select tools
ASUS D550MA-DS01 Battery Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
24
Past 30 Days:
107
All Time:
6,337
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If your battery is worn or defective, this guide will show you how to replace your battery. The battery is located internally in the laptop and requires removal of the keyboard module for access.
    1. ASUS D550MA-DS01 Battery Replacement, Keyboard Module: step 1, image 1 of 2 ASUS D550MA-DS01 Battery Replacement, Keyboard Module: step 1, image 2 of 2
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
      Ask FixBot
    2. ASUS D550MA-DS01 Battery Replacement: step 2, image 1 of 1
      • Turn the laptop over and open the display.
      • Insert the flat edge of the spudger into the crease of the keyboard cover.
      • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
      • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
      Ask FixBot
    3. ASUS D550MA-DS01 Battery Replacement: step 3, image 1 of 2 ASUS D550MA-DS01 Battery Replacement: step 3, image 2 of 2
      • Make sure that the entire cover has been released from the plastic clips.
      • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
      • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
      Ask FixBot
    4. ASUS D550MA-DS01 Battery Replacement: step 4, image 1 of 1
      • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
      • Disconnect the three data cables from the motherboard.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
      Ask FixBot
    5. ASUS D550MA-DS01 Battery Replacement: step 5, image 1 of 1
      • Remove the fully disconnected keyboard module from the laptop.
      Ask FixBot
    1. ASUS D550MA-DS01 Battery Replacement, Battery: step 6, image 1 of 2 ASUS D550MA-DS01 Battery Replacement, Battery: step 6, image 2 of 2
      • Do not use any metal tool to pry any type of battery. Doing so can puncture or short the battery, resulting in damage or injury.
      • Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
      Ask FixBot
    2. ASUS D550MA-DS01 Battery Replacement: step 7, image 1 of 2 ASUS D550MA-DS01 Battery Replacement: step 7, image 2 of 2
      • Lift the battery out and remove it:
      • The battery is connected to the motherboard on the left side.
      • Use your fingertips to evenly grip the battery on the left and right sides of the battery.
      • Pull straight up to lift the battery out of its place.
      • Do not use excessive force or attempt to pry the battery with any tools. Doing so will result in damage to the laptop.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
10 other people completed this guide.
Author
with
Richard Johnson
707 Reputation
5 Guides authored
IUPUI, Team 1-2, Baechle Fall 2015 Member of IUPUI, Team 1-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G2
3 Members
96 Guides authored
2 Guide Comments
No need to disconnect the ribbon cables to gain access to the battery. Gently move keyboard toward you to expose the battery.
Robert Beasley - Reply Share
Very nice and well explained! Bravo! Easy steps! Congratulations! :-)
MIGUEL MORENO - Reply Share
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 107
All Time: 6,337
