ASUS Chromebook CXB170CKA-BCL64N6 Back Panel Replacement
  1. ASUS Chromebook CXB170CKA-BCL64N6 Back Panel Replacement, Back Panel: step 1, image 1 of 3 ASUS Chromebook CXB170CKA-BCL64N6 Back Panel Replacement, Back Panel: step 1, image 2 of 3 ASUS Chromebook CXB170CKA-BCL64N6 Back Panel Replacement, Back Panel: step 1, image 3 of 3
    • Flip the device over to have the back panel facing towards you.
    • Remove eleven 7.2mm screws from the back panel using a Phillips #00 screwdriver.
    • Place an opening tool between the back panel and seam of the mainframe.
    • Gently insert the opening tool into the seam and slide it around the entire frame until the back panel releases.
    • Remove the back panel and set it to the side.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 58
