ASUS Chromebook C424MA-DH48F Touchpad Replacement
    1. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Lower Case: step 1, image 1 of 2 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Lower Case: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
      • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
      • Insert an opening pick into the gap between the lower case and chassis.
      • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: step 2, image 1 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: step 2, image 2 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: step 2, image 3 of 3
      • Use an opening tool to pop up the silver locking bar securing the battery connector.
      • Push the battery connector directly out of its motherboard port.
      Ask FixBot
    1. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: step 3, image 1 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: step 3, image 2 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: step 3, image 3 of 3
      • Carefully use the plastic prying tool and pop up the locking bar and lift the connector off with your hand.
      Ask FixBot
    2. ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 4, image 1 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 4, image 2 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the six 4.1 mm screws that secure the battery.
      • The two screw holes (marked in orange) on the bottom won't have screws associated with them since they were removed earlier when the base was removed.
      • Unseat the speaker cable from the black plastic hooks on the lower side of the battery.
      • Lift the battery up and out of the chassis.
      Ask FixBot
    1. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Touchpad: step 5, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the three 1.9 mm screws that secure the touchpad.
      Ask FixBot
    2. ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 6, image 1 of 1
      • Carefully peel off the gray tape on the touchpad.
      Ask FixBot
    3. ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 7, image 1 of 2 ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 7, image 2 of 2
      • Use an opening tool to flip up the black ZIF locking flap that secures the ribbon cable connector to the touchpad.
      • Pinch both sides of the ribbon cable connector and gently pull straight back to disconnect the touchpad.
      • Be very careful as the ribbon cable is fragile and can rip easily.
      Ask FixBot
    4. ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 8, image 1 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 8, image 2 of 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: step 8, image 3 of 3
      • Lift the touchpad up and out of the chassis.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 278
