ASUS Chromebook C424MA-DH48F Battery Replacement
    1. ASUS Chromebook C424MA-DH48F Battery Replacement, Lower Case: step 1, image 1 of 2 ASUS Chromebook C424MA-DH48F Battery Replacement, Lower Case: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
      • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
      • Insert an opening pick into the gap between the lower case and chassis.
      • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: step 2, image 1 of 3 ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: step 2, image 2 of 3 ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: step 2, image 3 of 3
      • Use an opening tool to pop up the silver locking bar securing the battery connector.
      • Push the battery connector directly out of its motherboard port.
      Ask FixBot
    1. ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: step 3, image 1 of 3 ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: step 3, image 2 of 3 ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: step 3, image 3 of 3
      • Carefully use the plastic prying tool and pop up the locking bar and lift the connector off with your hand.
      Ask FixBot
    2. ASUS Chromebook C424MA-DH48F Battery Replacement: step 4, image 1 of 3 ASUS Chromebook C424MA-DH48F Battery Replacement: step 4, image 2 of 3 ASUS Chromebook C424MA-DH48F Battery Replacement: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the six 4.1 mm screws that secure the battery.
      • The two screw holes (marked in orange) on the bottom won't have screws associated with them since they were removed earlier when the base was removed.
      • Unseat the speaker cable from the black plastic hooks on the lower side of the battery.
      • Lift the battery up and out of the chassis.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 515
