ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement
    1. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement, Keyboard & Trackpad Assembly: step 1, image 1 of 1
      • Flip the Chromebook over so the bottom of the device is facing up.
      Ask FixBot
    2. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 2, image 1 of 2 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 2, image 2 of 2
      • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
      • (5) Five 6mm screws
      • (6) Six 8mm screws
      Ask FixBot
    3. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 3, image 1 of 3 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 3, image 2 of 3 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 3, image 3 of 3
      • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
      Ask FixBot
    4. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 4, image 1 of 3 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 4, image 2 of 3 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: step 4, image 3 of 3
      • Gently detach connecting cables.
      • Carefully flip up the large black tab.
      • Carefully flip up small white tab.
      • Remove the corresponding black cable.
      • Remove the corresponding white cable.
      • The keyboard will be fully detached at this point.
      Ask FixBot
Gina Altimari
401 Reputation
4 Guides authored
USF Tampa, Team S2-G5, Passmore Fall 2017 Member of USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 373
