ASUS Chromebook C300MA-DH01 Battery Replacement
    1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: step 1, image 1 of 1
      • Flip the Chromebook over so the bottom of the device is facing up.
      Ask FixBot
    2. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 2, image 1 of 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 2, image 2 of 2
      • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
      • (5) Five 6mm screws
      • (6) Six 8mm screws
      Ask FixBot
    3. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 3, image 1 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 3, image 2 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 3, image 3 of 3
      • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
      Ask FixBot
    4. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 4, image 1 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 4, image 2 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 4, image 3 of 3
      • Gently detach connecting cables:
      • Carefully flip up the large black tab.
      • Carefully flip up small white tab.
      • Remove the corresponding black cable.
      • Remove the corresponding white cable.
      • The keyboard will be fully detached at this point.
      Ask FixBot
    5. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 5, image 1 of 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 5, image 2 of 2
      • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
      Ask FixBot
    6. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 6, image 1 of 1
      • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
      • The battery will be fully detached at this point. Carefully lift it out of the device.
      Ask FixBot
amer khalil
101 Reputation
1 Guide authored
USF Tampa, Team S2-G5, Passmore Fall 2017 Member of USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 104
All Time: 596
