ASUS Chromebook C204MA Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
54
All Time:
307
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A healthy motherboard is completely crucial to your laptop's health and productivity and when you have a faculty motherboard, this can lead to the device running into certain problems. These problems can be not powering on at all to performance problems like random shutdowns, freezing, and blue screen errors.
Certain problems can even lead to more issues such as components not being recognized, display problems, and even cause damage to other hardware like the CPU, RAM or storage devices due to insufficient power.
Before checking out this guide, make sure to check out the Asus Chromebook C204MA Won't Charge Troubleshooting Guide to see if some these underlying issues can be addressed and resolved through the troubleshooting guide.
Tools
    1. ASUS Chromebook C204MA Motherboard Replacement, Battery: step 1, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement, Battery: step 1, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement, Battery: step 1, image 3 of 3
      • Close the lid and set the laptop with down the bottom facing up.
      • Use a Phillips #0 screwdriver to remove the following screws:
      • Six 6 mm-long
      • Four 8 mm-long
      • Lift and remove the panel.
      Ask FixBot
    2. ASUS Chromebook C204MA Motherboard Replacement: step 2, image 1 of 1
      • Inside the cable panel, remove the four Phillips #0 4 mm-long screws.
      Ask FixBot
    3. ASUS Chromebook C204MA Motherboard Replacement: step 3, image 1 of 2 ASUS Chromebook C204MA Motherboard Replacement: step 3, image 2 of 2
      • Remove the black battery connector cover.
      Ask FixBot
    4. ASUS Chromebook C204MA Motherboard Replacement: step 4, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 4, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 4, image 3 of 3
      • Lift the flap securing the keyboard ribbon cable and disconnect the ribbon cable.
      Ask FixBot
    5. ASUS Chromebook C204MA Motherboard Replacement: step 5, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 5, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 5, image 3 of 3
      • Lift the locking flap securing the trackpad ribbon cable and disconnect the ribbon cable.
      Ask FixBot
    6. ASUS Chromebook C204MA Motherboard Replacement: step 6, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 6, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 6, image 3 of 3
      • Lift the locking flap securing the ribbon cable then disconnect the cable.
      Ask FixBot
    7. ASUS Chromebook C204MA Motherboard Replacement: step 7, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 7, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 7, image 3 of 3
      • Lift the locking flap and disconnect the ribbon cable.
      Ask FixBot
    8. ASUS Chromebook C204MA Motherboard Replacement: step 8, image 1 of 2 ASUS Chromebook C204MA Motherboard Replacement: step 8, image 2 of 2
      • Use tweezers to lift the orange press connector and disconnect it.
      • Make sure to not let it fall back onto its port, it will reconnect.
      Ask FixBot
    9. ASUS Chromebook C204MA Motherboard Replacement: step 9, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 9, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 9, image 3 of 3
      • Lift up the silver hinge securing the battery connector and disconnect the battery connector.
      Ask FixBot
    10. ASUS Chromebook C204MA Motherboard Replacement: step 10, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 10, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 10, image 3 of 3
      • Lift up the tape covering the display cable.
      • Lift the locking bar securing the display cable.
      • Disconnect the display cable.
      Ask FixBot
    11. ASUS Chromebook C204MA Motherboard Replacement: step 11, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 11, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 11, image 3 of 3
      • Remove the black foam piece.
      • Disconnect the two coaxial cables.
      Ask FixBot
    12. ASUS Chromebook C204MA Motherboard Replacement: step 12, image 1 of 2 ASUS Chromebook C204MA Motherboard Replacement: step 12, image 2 of 2
      • Flip over the laptop and open the lid to a full 180 degrees.
      • Insert an opening pick into the seam between the palm rest assembly and chassis.
      • Slide the opening pick around the perimeter until the palm rest assembly fully releases.
      • Remove the palm rest assembly.
      Ask FixBot
    13. ASUS Chromebook C204MA Motherboard Replacement: step 13, image 1 of 2 ASUS Chromebook C204MA Motherboard Replacement: step 13, image 2 of 2
      • On the I/O board on the right half of the laptop, lift the black mylar film and unscrew the single 4 mm-long Phillips #0 screw.
      • Lift off the orange cable and black mylar film and set aside.
      Ask FixBot
    14. ASUS Chromebook C204MA Motherboard Replacement: step 14, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 14, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 14, image 3 of 3
      • Lift up the locking flap securing the I/O board ribbon cable and disconnect the cable.
      Ask FixBot
    15. ASUS Chromebook C204MA Motherboard Replacement: step 15, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 15, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 15, image 3 of 3
      • Lift up the locking flap securing the second I/O board ribbon cable and disconnect the ribbon cable.
      Ask FixBot
    16. ASUS Chromebook C204MA Motherboard Replacement: step 16, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 16, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 16, image 3 of 3
      • In order to remove the motherboard to reach closer towards the battery, these are the steps required.
      • Remove the following screws with a Phillips screwdriver: two 5 mm-long black screws by the upper left of motherboard; one 4 mm-long sliver screw upper middle of the motherboard and one 4 mm-long sliver screw by the bottom left corner of motherboard.
      Ask FixBot
    17. ASUS Chromebook C204MA Motherboard Replacement: step 17, image 1 of 1
      • Unscrew two 4 mm-long sliver screws at the sliver thermal support bracket, located at the bottom left and middle right.
      Ask FixBot
    18. ASUS Chromebook C204MA Motherboard Replacement: step 18, image 1 of 2 ASUS Chromebook C204MA Motherboard Replacement: step 18, image 2 of 2
      • Using your hands lift mother board slightly up and pull to the right slowly until motherboard is free.
      Ask FixBot
    19. ASUS Chromebook C204MA Motherboard Replacement: step 19, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 19, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 19, image 3 of 3
      • Upon removal of motherboard, move motherboard and left side speaker out of the way.
      • Remove the three 4 mm-long sliver screws located on the right side of upper right portion of battery, bottom right portion of battery and far bottom left of battery (located next to speaker)
      Ask FixBot
    20. ASUS Chromebook C204MA Motherboard Replacement: step 20, image 1 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 20, image 2 of 3 ASUS Chromebook C204MA Motherboard Replacement: step 20, image 3 of 3
      • Lift black tape on the bottom right side of the battery.
      • Unravel black speaker cord across battery with tweezers.
      Ask FixBot
    21. ASUS Chromebook C204MA Motherboard Replacement: step 21, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. ASUS Chromebook C204MA Motherboard Replacement, Motherboard: step 22, image 1 of 1
      • Peel the tape and thread the Touchpad Cable through its slot.
      Ask FixBot
    2. ASUS Chromebook C204MA Motherboard Replacement: step 23, image 1 of 1
      • Gently lift the motherboard up and out.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Damien Jennings
1,086 Reputation
5 Guides authored
Texas Tech, Team 45-67, Weston Fall 2025 Member of Texas Tech, Team 45-67, Weston Fall 2025
TTU-WESTON-F25S45G67
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 54
All Time: 307
