ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement
    1. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement, Lower Case: step 1, image 1 of 1
      • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
      Ask FixBot
    2. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: step 2, image 1 of 1
      • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
      Ask FixBot
    3. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
      • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
      Ask FixBot
    4. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: step 4, image 1 of 1
      • Use the iFixit opening tool to remove the back of the laptop.
      Ask FixBot
    5. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: step 5, image 1 of 1
      • Use the blunt nose tweezers to separate the keyboard from the internal components.
      Ask FixBot
Tiffany Foo
289 Reputation
2 Guides authored
Cal Poly, Team S19-G4, White Winter 2019 Member of Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 52
All Time: 483
