Up to 20% off select tools
ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
48
All Time:
869
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 - 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Details to remove the keyboard of ASUS Chromebook Flip C100PA-RBRKT07
    1. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Lower Case: step 1, image 1 of 1
      • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
      Ask FixBot
    2. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: step 2, image 1 of 1
      • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
      Ask FixBot
    3. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
      • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
      Ask FixBot
    4. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: step 4, image 1 of 1
      • Use the iFixit opening tool to remove the back of the laptop.
      Ask FixBot
    5. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: step 5, image 1 of 1
      • Use the blunt nose tweezers to separate the keyboard from the internal components.
      Ask FixBot
    1. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: step 6, image 1 of 2 ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: step 6, image 2 of 2
      • Remove the keyboard from the laptop.
      • The Trackpad is attached to the keyboard assembly. The Trackpad replacement guide can be found on the ASUS Chromebook CPPA-RBRKT07 homepage.
      Ask FixBot
Author
with
Anthony Gomez
94 Reputation
1 Guide authored
Cal Poly, Team S19-G4, White Winter 2019 Member of Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 48
All Time: 869
