ASUS Chromebook C100PA-RBRKT07 Battery Replacement
    1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: step 1, image 1 of 1
      • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
      Ask FixBot
    2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 2, image 1 of 1
      • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
      Ask FixBot
    3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
      • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
      Ask FixBot
    4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 4, image 1 of 1
      • Use the iFixit opening tool to pry the backing of the device off.
      Ask FixBot
    5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 5, image 1 of 1
      • Use the tweezers to separate the cables from the motherboard.
      • You need to reach inside and peel some tape to disconnect the wire.
      Ask FixBot
    6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 6, image 1 of 1
      • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
      Ask FixBot
    7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 7, image 1 of 2 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 7, image 2 of 2
      • Gently disconnect the audio cards, exposing the battery.
      Ask FixBot
    8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 8, image 1 of 1
      • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
      Ask FixBot
    9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 9, image 1 of 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 9, image 2 of 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: step 9, image 3 of 3
      • Grip the battery and remove it from the device.
      • Remove the battery cable out of the motherboard by lifting the battery cables.
      Ask FixBot
Tiffany Foo
289 Reputation
2 Guides authored
Cal Poly, Team S19-G4, White Winter 2019 Member of Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 62
All Time: 798
