Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
ASS RCD does not trip
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
88
All Time:
625
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
If you touch a live part and get an electric shock, the residual current device (RCD) detects it and switches off in a flash.
Having such a safety switch on your cable makes you feel safe (and rightly so), whether you're working on electronics or trimming your hedge.
It's just a problem if the protection fails at the critical moment......
    1. ASS RCD does not trip, unscrewing: step 1, image 1 of 1
      • the circuit breaker works with the IC RV4145, which requires 26V, but there are 230V on the line, the excess is 'burned off' in a large resistor
      • directly next to the resistor sits (stands) a small electrolytic capacitor, a design flaw, because electrolytic capacitors do not like heat ..... after a few years they are defective
      • and the dangerous thing here is, you don't notice anything ..... current still flows .......
      • Only by pressing the 'Test' button do you notice the defect!
      Ask FixBot
    2. ASS RCD does not trip, Replace electrolytic capacitor: step 2, image 1 of 2 ASS RCD does not trip, Replace electrolytic capacitor: step 2, image 2 of 2
      • Desolder the defective electrolytic capacitor.
      • To make the new electrolytic capacitor last longer, install it on the underside... it is not as hot there.
      • Observe the polarity, see the photo for +.
      • When testing without switching off, the small test resistance can burn out and must then also be replaced; 6.8 kΩ for 30mA RCD (18 kΩ in the photo).
      Ask FixBot
    3. ASS RCD does not trip, testing !: step 3, image 1 of 1
      • so, attention, such an RCD is not 'fail-safe'
      • therefore regularly press the 'Test' button !
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Author
with
Gottfried Silberhorn
1,819 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 88
All Time: 625
