APS Tech 101629 SCSI Connections Replacement
    1. APS Tech 101629 SCSI Connections Replacement, External Casing: step 1, image 1 of 3 APS Tech 101629 SCSI Connections Replacement, External Casing: step 1, image 2 of 3 APS Tech 101629 SCSI Connections Replacement, External Casing: step 1, image 3 of 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Ask FixBot
    2. APS Tech 101629 SCSI Connections Replacement: step 2, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 2, image 2 of 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Ask FixBot
    3. APS Tech 101629 SCSI Connections Replacement: step 3, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 3, image 2 of 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Ask FixBot
    4. APS Tech 101629 SCSI Connections Replacement: step 4, image 1 of 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Ask FixBot
    5. APS Tech 101629 SCSI Connections Replacement: step 5, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 5, image 2 of 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Ask FixBot
    1. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: step 6, image 1 of 2 APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: step 6, image 2 of 2
      • Flip so device is upside down.
      • Remove 4 screws with Phillips #1 screw driver.
      • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
      Ask FixBot
    2. APS Tech 101629 SCSI Connections Replacement: step 7, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 7, image 2 of 2
      • Slide the internal drive component away from the back of the device.
      • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
      • Audio Connection
      • SCSI ID
      • Terminate On
      • SCSI Connection
      • DC Input (power)
      Ask FixBot
    1. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: step 8, image 1 of 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: step 8, image 2 of 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: step 8, image 3 of 3
      • Remove the four Phillips #1 Screws from back panel.
      • Once the screws are removed, the two connections are easily removed from the body.
      Ask FixBot
Patrick Meyer
83 Reputation
3 Guides authored
Cal Poly, Team 24-60, Amido Spring 2011 Member of Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,360
