Up to 20% off select tools
APS Tech 101629 Power Switch Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
86
All Time:
1,310
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This repair guide will guide you through the steps to removing and replacing the power switch of your APS Tech 101629 CD-Drive.
First the external casing, and channel switch will need to be removed.
    1. APS Tech 101629 Power Switch Replacement, External Casing: step 1, image 1 of 3 APS Tech 101629 Power Switch Replacement, External Casing: step 1, image 2 of 3 APS Tech 101629 Power Switch Replacement, External Casing: step 1, image 3 of 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Ask FixBot
    2. APS Tech 101629 Power Switch Replacement: step 2, image 1 of 2 APS Tech 101629 Power Switch Replacement: step 2, image 2 of 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Ask FixBot
    3. APS Tech 101629 Power Switch Replacement: step 3, image 1 of 2 APS Tech 101629 Power Switch Replacement: step 3, image 2 of 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Ask FixBot
    4. APS Tech 101629 Power Switch Replacement: step 4, image 1 of 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Ask FixBot
    5. APS Tech 101629 Power Switch Replacement: step 5, image 1 of 2 APS Tech 101629 Power Switch Replacement: step 5, image 2 of 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Ask FixBot
    1. APS Tech 101629 Power Switch Replacement, Channel Switch: step 6, image 1 of 2 APS Tech 101629 Power Switch Replacement, Channel Switch: step 6, image 2 of 2
      • Find the conjoined ID cable wires that are colored black, orange, and yellow.
      • Lift white portion of cable wires to disconnect it.
      Ask FixBot
    2. APS Tech 101629 Power Switch Replacement: step 7, image 1 of 3 APS Tech 101629 Power Switch Replacement: step 7, image 2 of 3 APS Tech 101629 Power Switch Replacement: step 7, image 3 of 3
      • At this point, the fan is loose and can be easily moved but not disconnected.
      • Using the spudger, depress the pressure holders at all four corners of the fan.
      • Take out the fan and its cords, by pulling it outward from its cavity within the device.
      Ask FixBot
    1. APS Tech 101629 Power Switch Replacement, Power Switch: step 8, image 1 of 2 APS Tech 101629 Power Switch Replacement, Power Switch: step 8, image 2 of 2
      • Depress 2 pressure holds on each side of the power switch.
      • Press out the back of the device.
      Ask FixBot
    2. APS Tech 101629 Power Switch Replacement: step 9, image 1 of 2 APS Tech 101629 Power Switch Replacement: step 9, image 2 of 2
      • Remove all four 4 connections from the power switch.
      • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
      • These are very hard to get off, use patience and wiggling.
      Ask FixBot
Author
with
Alexis Weckel
140 Reputation
3 Guides authored
Cal Poly, Team 24-60, Amido Spring 2011 Member of Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 86
All Time: 1,310
