Up to 20% off select tools
APS Tech 101629 Internal Drive Component Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
1,828
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This repair guide will walk you through the steps to removing and replacing the internal drive component of your APS Tech 101629 CD-Drive. First the external casing will need to be removed.
    1. APS Tech 101629 Internal Drive Component Replacement, External Casing: step 1, image 1 of 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: step 1, image 2 of 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: step 1, image 3 of 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Ask FixBot
    2. APS Tech 101629 Internal Drive Component Replacement: step 2, image 1 of 2 APS Tech 101629 Internal Drive Component Replacement: step 2, image 2 of 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Ask FixBot
    3. APS Tech 101629 Internal Drive Component Replacement: step 3, image 1 of 2 APS Tech 101629 Internal Drive Component Replacement: step 3, image 2 of 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Ask FixBot
    4. APS Tech 101629 Internal Drive Component Replacement: step 4, image 1 of 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Ask FixBot
    5. APS Tech 101629 Internal Drive Component Replacement: step 5, image 1 of 2 APS Tech 101629 Internal Drive Component Replacement: step 5, image 2 of 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Ask FixBot
    1. APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: step 6, image 1 of 2 APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: step 6, image 2 of 2
      • Flip so device is upside down.
      • Remove 4 screws with Phillips #1 screw driver.
      • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
      Ask FixBot
    2. APS Tech 101629 Internal Drive Component Replacement: step 7, image 1 of 2 APS Tech 101629 Internal Drive Component Replacement: step 7, image 2 of 2
      • Slide the internal drive component away from the back of the device.
      • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
      • Audio Connection
      • SCSI ID
      • Terminate On
      • SCSI Connection
      • DC Input (power)
      Ask FixBot
2 other people completed this guide.
Author
with
Alexis Weckel
140 Reputation
3 Guides authored
Cal Poly, Team 24-60, Amido Spring 2011 Member of Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 1,828
