Up to 20% off select tools
APS Tech 101629 External Casing Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
87
All Time:
1,469
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This is one of the easier disassembly guides for this device. The case is easily removed, but will void any still existing warranty on the device. Removing the case is necessary to get at any internal component.
    1. APS Tech 101629 External Casing Replacement, External Casing: step 1, image 1 of 3 APS Tech 101629 External Casing Replacement, External Casing: step 1, image 2 of 3 APS Tech 101629 External Casing Replacement, External Casing: step 1, image 3 of 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Ask FixBot
    2. APS Tech 101629 External Casing Replacement: step 2, image 1 of 2 APS Tech 101629 External Casing Replacement: step 2, image 2 of 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Ask FixBot
    3. APS Tech 101629 External Casing Replacement: step 3, image 1 of 2 APS Tech 101629 External Casing Replacement: step 3, image 2 of 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Ask FixBot
    4. APS Tech 101629 External Casing Replacement: step 4, image 1 of 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Ask FixBot
    5. APS Tech 101629 External Casing Replacement: step 5, image 1 of 2 APS Tech 101629 External Casing Replacement: step 5, image 2 of 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Ask FixBot
Author
with
Patrick Meyer
83 Reputation
3 Guides authored
Cal Poly, Team 24-60, Amido Spring 2011 Member of Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 87
All Time: 1,469
