APS Tech 101629 Exhaust Fan Replacement
    1. APS Tech 101629 Exhaust Fan Replacement, External Casing: step 1, image 1 of 3 APS Tech 101629 Exhaust Fan Replacement, External Casing: step 1, image 2 of 3 APS Tech 101629 Exhaust Fan Replacement, External Casing: step 1, image 3 of 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Ask FixBot
    2. APS Tech 101629 Exhaust Fan Replacement: step 2, image 1 of 2 APS Tech 101629 Exhaust Fan Replacement: step 2, image 2 of 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Ask FixBot
    3. APS Tech 101629 Exhaust Fan Replacement: step 3, image 1 of 2 APS Tech 101629 Exhaust Fan Replacement: step 3, image 2 of 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Ask FixBot
    4. APS Tech 101629 Exhaust Fan Replacement: step 4, image 1 of 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Ask FixBot
    5. APS Tech 101629 Exhaust Fan Replacement: step 5, image 1 of 2 APS Tech 101629 Exhaust Fan Replacement: step 5, image 2 of 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Ask FixBot
    1. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: step 6, image 1 of 2 APS Tech 101629 Exhaust Fan Replacement, Channel Switch: step 6, image 2 of 2
      • Find the conjoined ID cable wires that are colored black, orange, and yellow.
      • Lift white portion of cable wires to disconnect it.
      Ask FixBot
    2. APS Tech 101629 Exhaust Fan Replacement: step 7, image 1 of 3 APS Tech 101629 Exhaust Fan Replacement: step 7, image 2 of 3 APS Tech 101629 Exhaust Fan Replacement: step 7, image 3 of 3
      • At this point, the fan is loose and can be easily moved but not disconnected.
      • Using the spudger, depress the pressure holders at all four corners of the fan.
      • Take out the fan and its cords, by pulling it outward from its cavity within the device.
      Ask FixBot
    1. APS Tech 101629 Exhaust Fan Replacement, Power Switch: step 8, image 1 of 2 APS Tech 101629 Exhaust Fan Replacement, Power Switch: step 8, image 2 of 2
      • Depress 2 pressure holds on each side of the power switch.
      • Press out the back of the device.
      Ask FixBot
    2. APS Tech 101629 Exhaust Fan Replacement: step 9, image 1 of 2 APS Tech 101629 Exhaust Fan Replacement: step 9, image 2 of 2
      • Remove all four 4 connections from the power switch.
      • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
      • These are very hard to get off, use patience and wiggling.
      Ask FixBot
    1. APS Tech 101629 Exhaust Fan Replacement, Exhaust Fan: step 10, image 1 of 1
      • Remove temperature guage.
      Ask FixBot
    2. APS Tech 101629 Exhaust Fan Replacement: step 11, image 1 of 3 APS Tech 101629 Exhaust Fan Replacement: step 11, image 2 of 3 APS Tech 101629 Exhaust Fan Replacement: step 11, image 3 of 3
      • Move the exhaust fan out of the way so you can access its control cord.
      • Use the spudger to depress the hold on the fan cord.
      • Gently pull fan cord from connection and remove fan completely.
      Ask FixBot
Patrick Meyer
83 Reputation
3 Guides authored
Cal Poly, Team 24-60, Amido Spring 2011 Member of Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,140
