Up to 20% off select tools
APEX TM785CH Battery Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
97
All Time:
2,820
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
The guide is written to replace the device's battery if the battery does not hold a charge well or does not function at all.
You will need an opening tool for removing the cover and a soldering kit for removing the wires.
Caution: Never puncture or excessively bend the battery during removal. This can cause extreme heat and possible injury.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
    1. APEX TM785CH Battery Replacement, Back Casing: step 1, image 1 of 2 APEX TM785CH Battery Replacement, Back Casing: step 1, image 2 of 2
      • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
      • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
      • Move along the top edge of the tablet and repeat the step above.
      • Pull the back cover away from the tablet body to completely remove it.
      Ask FixBot
    1. APEX TM785CH Battery Replacement, Battery: step 2, image 1 of 2 APEX TM785CH Battery Replacement, Battery: step 2, image 2 of 2
      • With the back cover removed, you can now see the battery.
      • You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
      Ask FixBot
2 other people completed this guide.
Author
with
Brian Graschel
823 Reputation
6 Guides authored
Baylor, Team 4-1, Williams Spring 2015 Member of Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 97
All Time: 2,820
