APC Smart-UPS SC 450VA Battery Replacement
  1. APC Smart-UPS SC 450VA Battery Replacement, Remove the faceplate: step 1, image 1 of 1
    • Pull on the left corner of the faceplate to remove it.
    Ask FixBot
  2. APC Smart-UPS SC 450VA Battery Replacement, Unscrew the battery cover: step 2, image 1 of 1
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • Use a PH2 screwdriver to unscrew the 4 screws securing the battery cover.
    Ask FixBot
  3. APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: step 3, image 1 of 2 APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: step 3, image 2 of 2
    • Use the pull tab to pull out the battery.
    • Be sure to not pinch the cables between the case and the battery.
    • Unplug the battery connector.
    • Remove the battery.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals.
    Ask FixBot
Sebastian
33,346 Reputation
72 Guides authored
4 Guide Comments
this is incorrect, since 1995 all Smart UPS have hot swappable batteries. no need to turn it off, that's the whole point of it being in the front of the device - https://www.apc.com/us/en/faqs/FA303216/
Ryan Matthews - Reply Share
Thank you, the guide has been adjusted.
Sebastian - Reply Share
After hot swapping the battery replacement my replace battery LED is still lit. How do I reset that?
Michael Dickson - Reply Share
You can press and hold the power button for a few seconds to manually run a self-test or just wait until it reaches the next scheduled self-test (every 7 or 14 days depending on configuration). It is recommended to wait at least 24 hours before performing the self test as the new battery needs time to reach capacity.
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 180
All Time: 9,667
