APC RBC44 Battery Cartridge Battery Replacement
  1. APC RBC44 Battery Cartridge Battery Replacement, Removing the Cover: step 1, image 1 of 3 APC RBC44 Battery Cartridge Battery Replacement, Removing the Cover: step 1, image 2 of 3 APC RBC44 Battery Cartridge Battery Replacement, Removing the Cover: step 1, image 3 of 3
    • Locate the two screws on the far side of the unit, the end opposite of the plug connection.
    • Use a philips head screw driver to remove the two screws.
    • Remove the cover by first sliding it towards the plug end and lift up on the cover to remove it.
    Ask FixBot
  2. APC RBC44 Battery Cartridge Battery Replacement, Make A Wiring Guide: step 2, image 1 of 3 APC RBC44 Battery Cartridge Battery Replacement, Make A Wiring Guide: step 2, image 2 of 3 APC RBC44 Battery Cartridge Battery Replacement, Make A Wiring Guide: step 2, image 3 of 3
    • Remove the two black plastic wiring covers on each side of the battery cartridge
    • There are a total of eight batteries in the cartridge, the goal for this step is to either make or snap a picture using your phone of the wiring that you can reference later on.
    • I have provided a full diagram in the third step -
    Ask FixBot
  3. APC RBC44 Battery Cartridge Battery Replacement, Remove the Wires from the Batteries: step 3, image 1 of 3 APC RBC44 Battery Cartridge Battery Replacement, Remove the Wires from the Batteries: step 3, image 2 of 3 APC RBC44 Battery Cartridge Battery Replacement, Remove the Wires from the Batteries: step 3, image 3 of 3
    • Since you now have a wiring diagram, you will now be removing all of the wires from the batteries in the cartridge.
    • Use a pair of needle nose pliers to remove the wires from the terminals of the batteries
    • See the third pictures for the proper placement of the needle nose pliers on the plastic portion of the wire. This is the easiest spot to apply pressure to and pull back on to release the clip from the terminal.
    Ask FixBot
  4. APC RBC44 Battery Cartridge Battery Replacement, Remove the Batteries: step 4, image 1 of 2 APC RBC44 Battery Cartridge Battery Replacement, Remove the Batteries: step 4, image 2 of 2
    • Remove all of the batteries from the cartridge one by one.
    • For help on getting the first battery out of the cartridge you can use your pair of needle nose pliers to pull the battery up and out.
    Ask FixBot
  5. APC RBC44 Battery Cartridge Battery Replacement, Fill the cartridge with your new batteries: step 5, image 1 of 3 APC RBC44 Battery Cartridge Battery Replacement, Fill the cartridge with your new batteries: step 5, image 2 of 3 APC RBC44 Battery Cartridge Battery Replacement, Fill the cartridge with your new batteries: step 5, image 3 of 3
    • Use the wiring diagram made in step three to fill the cartridge with your brand new replacement batteries.
    Ask FixBot
  6. APC RBC44 Battery Cartridge Battery Replacement, Make the 1st and 2nd connection: step 6, image 1 of 3 APC RBC44 Battery Cartridge Battery Replacement, Make the 1st and 2nd connection: step 6, image 2 of 3 APC RBC44 Battery Cartridge Battery Replacement, Make the 1st and 2nd connection: step 6, image 3 of 3
    • Connect the very first wire to the negative terminal of the battery. This will be on the left hand side of the cartridge - the side where the plug is located.
    • For the last part of this step you will be connecting the fuse to the negative and positive of battery two and three as shown in picture two and three.
    Ask FixBot
Richard Price
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,260
