APC Back-UPS 450 battery Replacement
    1. APC Back-UPS 450 battery Replacement, Turn OFF and UNPLUG UPS: step 1, image 1 of 3 APC Back-UPS 450 battery Replacement, Turn OFF and UNPLUG UPS: step 1, image 2 of 3 APC Back-UPS 450 battery Replacement, Turn OFF and UNPLUG UPS: step 1, image 3 of 3
      • Turn off and unplug your UPS from wall power, then turn it upside down.
      • Pull the yellow tab loose, to disconnect the battery.
      Ask FixBot
    2. APC Back-UPS 450 battery Replacement, Open case: step 2, image 1 of 3 APC Back-UPS 450 battery Replacement, Open case: step 2, image 2 of 3 APC Back-UPS 450 battery Replacement, Open case: step 2, image 3 of 3
      • Use a long number 1 Phillips screwdriver to remove 4 screws so you can open the case.
      • This may be difficult to find an appropriate screwdriver. You will also possibly need to gently pry between the two pieces of the case with a small flathead screwdriver to separate the two pieces of the case.
      Ask FixBot
    3. APC Back-UPS 450 battery Replacement, Disconnect, remove old battery, & install new: step 3, image 1 of 2 APC Back-UPS 450 battery Replacement, Disconnect, remove old battery, & install new: step 3, image 2 of 2
      • Disconnect and remove the battery from the case.
      • Install the new battery and connect it, noting the red and black color coating.
      Ask FixBot
    4. APC Back-UPS 450 battery Replacement, Reassemble and test: step 4, image 1 of 1
      • Reassembly is the reverse of removal.
      Ask FixBot
4 other people completed this guide.
Lance Wessel
611 Reputation
3 Guides authored
3 Guide Comments
Use a #1;phillips head screwdriver.
I own an APC RN450M. A #2:phillips head screwdriver doesn't work with that 450 VA model. In fact it doesn't even fit in the screw holes.
But a #1;phliips head screwdriver with at least an 8 inch shaft woks fine.
Bob Hyman - Reply Share
Agreed with @bobhyman, a #1 Phillips screwdriver is what's needed, although something a little shorter than 8 inches is probably OK too (measure the height of the entire unit as an upper bound). It might not be super-easy to find one of these at a local hardware store, but I ended up ordering something on Amazon. Other than that this is a pretty easy replacement. Thanks!
bmah - Reply Share
I used a #2, but it was a skinny one.
The yellow battery shutoff clip is what gave me the most problem, it was really tight in there!
Crissa Kentavr - Reply Share
Past 24 Hours: 26
Past 7 Days: 199
Past 30 Days: 789
All Time: 22,006
