Up to 20% off select tools
ANKER SoundCore Charging Port Replacement
Views: 14K
View statistics:
Past 24 Hours:
5
Past 7 Days:
41
Past 30 Days:
179
All Time:
14,303
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your ANKER SoundCore does not charge, your charging port may be broken. If you wish to replace your device’s charging port, you can follow this step-by-step guide.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
You will need an iFixit opening tool, Phillips #0 screwdriver, metal spludger, and iFixit opening pick. Soldering experience is needed.
    1. ANKER SoundCore Charging Port Replacement, Charging Port: step 1, image 1 of 3 ANKER SoundCore Charging Port Replacement, Charging Port: step 1, image 2 of 3 ANKER SoundCore Charging Port Replacement, Charging Port: step 1, image 3 of 3
      • Use the plastic opening tool to pry off the screen.
      • Remove the screen from the device.
      Ask FixBot
    2. ANKER SoundCore Charging Port Replacement: step 2, image 1 of 1
      • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
      Ask FixBot
    3. ANKER SoundCore Charging Port Replacement: step 3, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 3, image 2 of 2
      • Use the metal spludger to pry off speaker mount.
      Ask FixBot
    4. ANKER SoundCore Charging Port Replacement: step 4, image 1 of 1
      • Remove the two 8mm Phillips #0 screws from the circuit board.
      Ask FixBot
    5. ANKER SoundCore Charging Port Replacement: step 5, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 5, image 2 of 2
      • Carefully remove the circuit board from the speaker body.
      Ask FixBot
    6. ANKER SoundCore Charging Port Replacement: step 6, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 6, image 2 of 2
      • Use the iFixit Opening Pick to pry off the charging port cover.
      • Remove the charging port cover.
      Ask FixBot
    7. ANKER SoundCore Charging Port Replacement: step 7, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 7, image 2 of 2
      • Desolder the charging port from the circuit board.
      • Solder a new charging port in place of the old one.
      • For help soldering and desoldering, follow this guide.
      Ask FixBot
3 other people completed this guide.
Author
with
Briana Kuo
311 Reputation
1 Guide authored
Cal Poly, Team S22-G1, Regan Winter 2020 Member of Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Members
60 Guides authored
4 Guide Comments
Where can I find a replacement port that is compatible?
tommy2197 - Reply Share
Mike - Reply Share
The Charging port is an USB Mirco Port. To find right part search for JBL FLIP 3 on ebay or other platforms. It is the same part as used for the Anker SoundCore.
Agi - Reply Share
Hi I have a Anker soundcore motion plus, the charging port is loose and not charging, it's a usb c, where can I buy that replacement part
.thanks
Justin - Reply Share
Past 24 Hours: 5
Past 7 Days: 41
Past 30 Days: 179
All Time: 14,303
