AIAIAI Repair guide: UNIT-4 battery
  1. AIAIAI Repair guide: UNIT-4 battery, TOOLS: step 1, image 1 of 1
    • All you need is a thin, hard plastic tool or an old credit card and 2 cross head screwdrivers. We use a Phillips 00 and a Phillips 2.
    Ask FixBot
    • Make sure UNIT-4 is turned off.
    • Use a thin, hard plastic tool or an old credit card and pull off the front panel.
    Ask FixBot
    • Take a screwdriver and remove all 16 screws.
    • Place UNIT-4 upright and carefully lean forward while supporting the front as shown in the video.
    • If the front housing is too tight, we recommend using a flathead screwdriver or similar to pull the housing out. You can do this by pulling it out by the magnet locks.
    Ask FixBot
    • Disconnect the 6 connectors on the back edge of the main circuit board.
    Ask FixBot
  2. AIAIAI Repair guide: UNIT-4 battery, Remove battery pack screws and battery packs: step 5, image 1 of 2 AIAIAI Repair guide: UNIT-4 battery, Remove battery pack screws and battery packs: step 5, image 2 of 2
    • Take a screwdriver and remove the 2 screws from each side.
    • Lift out the battery packs.
    Ask FixBot
    • Slide battery packs in to place. The pack with the connectors is on the right hand side.
    • Push the connecting cable underneath the bass vent.
    • Hand tighten the 2 screws in each side.
    Ask FixBot
AIAIAI - Albert
913 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 220
