AIAIAI Repair guide: UNIT-4 Tweeter
      • All you need is a thin, hard plastic tool or an old credit card and 2 cross head screwdrivers. We use a Phillips 00 and a Phillips 2.
      Ask FixBot
      • Make sure UNIT-4 is turned off.
      • Use a thin, hard plastic tool or an old credit card and pull off the front panel.
      Ask FixBot
      • Take a screwdriver and remove all 16 screws as shown on the image below.
      • Place UNIT-4 upright and carefully lean forward while supporting the front as shown in the video.
      • If the front housing is too tight, we recommend using a flathead screwdriver or similar to pull the housing out. You can do this by pulling it out by the magnet locks.
      Ask FixBot
      • Use a thin and pointy tool to unlock the cable connectors.
      • Unscrew the 3 screws
      Ask FixBot
      • Carefully insert the new tweeter.
      • Connect the cable connectors.
      • Screw in the 3 screws.
      Ask FixBot
AIAIAI - Albert
913 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 149
