AEG Electrolux FM72 Disassembly for cleaning
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: step 1, image 1 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: step 1, image 2 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: step 1, image 3 of 3
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
    Ask FixBot
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: step 2, image 1 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: step 2, image 2 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: step 2, image 3 of 3
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
    Ask FixBot
  3. AEG Electrolux FM72 Disassembly for cleaning: step 3, image 1 of 3 AEG Electrolux FM72 Disassembly for cleaning: step 3, image 2 of 3 AEG Electrolux FM72 Disassembly for cleaning: step 3, image 3 of 3
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
    Ask FixBot
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: step 4, image 1 of 2 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: step 4, image 2 of 2
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
    Ask FixBot
3 other people completed this guide.
Kevin D
7,532 Reputation
21 Guides authored
3 Guide Comments
Hello
How can i repair the electric wire on this device please ?
Heloise - Reply Share
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - Reply Share
How can I disassemble the motor parts for cleaning?
wongkapo0611 - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 91
All Time: 7,760
