AEE Mach 1 Battery Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
70
All Time:
1,754
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show you how to properly remove and replace the battery from the AEE Mach 1 drone. It is important to first power off the device before beginning any repairs. Disassembly and replacement will not require any additional tools or skills. The process simply involves orienting the drone camera away from you, pressing the battery retainment tabs and pulling, followed by reinserting the new battery until hearing the tabs click.
    1. AEE Mach 1 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure that your device is powered off before doing any work.
      • The battery is located at the back of the drone, on the opposite end of the drone from the camera.
      • There are two tabs on the edge of each side of the battery.
      Ask FixBot
    2. AEE Mach 1 Battery Replacement: step 2, image 1 of 1
      • To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
      Ask FixBot
    3. AEE Mach 1 Battery Replacement: step 3, image 1 of 1
      • To replace the battery, simply slide it back into its place until the tabs click back into place. If you are having trouble doing this, you may be putting it in upside down. Try flipping it over and trying again.
      Ask FixBot
3 Guide Comments
purchase the aee mach 1 but it has no battery
Ulysses aka UL Salett - Reply Share
How do I get a new battery where do I look
haroldlknight55 - Reply Share
Hi, how do a o get a battery?
Nivaldo Santos - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 70
All Time: 1,754
