ACN Iris WG4K Video Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
73
All Time:
590
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 6 - 7 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The video camera is an essential part of the Iris WG4K video phone if you plan to make video calls. Sent video calls that result in black or glitched images could be a result of a faulty camera. This guide will explain step-by-step how to remove the camera from the phone so that you can replace it.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. ACN Iris WG4K Video Camera Replacement, Handset: step 1, image 1 of 2 ACN Iris WG4K Video Camera Replacement, Handset: step 1, image 2 of 2
      • Press upwards with your index finger on the 4P4C connector as shown in the image.
      • Pull the connector gently out of its socket.
      Ask FixBot
    1. ACN Iris WG4K Video Camera Replacement, Lower Case: step 2, image 1 of 1
      • Flip the main body of the video phone so that the bottom is facing up.
      • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
      Ask FixBot
    2. ACN Iris WG4K Video Camera Replacement: step 3, image 1 of 2 ACN Iris WG4K Video Camera Replacement: step 3, image 2 of 2
      • Lift the back case upwards to expose the inside components.
      • Red rectangles indicate the three ribbon cables.
      • The orange square indicates the blade connector.
      Ask FixBot
    3. ACN Iris WG4K Video Camera Replacement: step 4, image 1 of 3 ACN Iris WG4K Video Camera Replacement: step 4, image 2 of 3 ACN Iris WG4K Video Camera Replacement: step 4, image 3 of 3
      • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
      • Gently pull the ribbon cables out of their insulation-displacement connectors.
      Ask FixBot
    4. ACN Iris WG4K Video Camera Replacement: step 5, image 1 of 2 ACN Iris WG4K Video Camera Replacement: step 5, image 2 of 2
      • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
      • Gently pull the blade connector out of the blade receptacle.
      Ask FixBot
    5. ACN Iris WG4K Video Camera Replacement: step 6, image 1 of 1
      • Gently lift up the lower case to separate it from the top case.
      Ask FixBot
    1. ACN Iris WG4K Video Camera Replacement, Blade Connector: step 7, image 1 of 1
      Ask FixBot
    2. ACN Iris WG4K Video Camera Replacement: step 8, image 1 of 1
      • Gently lift up on the upper case to separate it from the keypad/speaker panel.
      Ask FixBot
    3. ACN Iris WG4K Video Camera Replacement: step 9, image 1 of 1
      • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
      Ask FixBot
    4. ACN Iris WG4K Video Camera Replacement: step 10, image 1 of 1
      • Rotate the top case 180 degrees so that the video screen is closest to you.
      • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
      • The four Phillips head screws (6 mm) are highlighted by the red circles.
      Ask FixBot
    5. ACN Iris WG4K Video Camera Replacement: step 11, image 1 of 1
      • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
      Ask FixBot
    6. ACN Iris WG4K Video Camera Replacement: step 12, image 1 of 1
      • Flip the top case so that the video screen is facing up.
      Ask FixBot
    7. ACN Iris WG4K Video Camera Replacement: step 13, image 1 of 1
      • Rotate the top case 180 degrees.
      • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
      Ask FixBot
    8. ACN Iris WG4K Video Camera Replacement: step 14, image 1 of 1
      • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
      Ask FixBot
    9. ACN Iris WG4K Video Camera Replacement: step 15, image 1 of 2 ACN Iris WG4K Video Camera Replacement: step 15, image 2 of 2
      • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
      Ask FixBot
    10. ACN Iris WG4K Video Camera Replacement: step 16, image 1 of 2 ACN Iris WG4K Video Camera Replacement: step 16, image 2 of 2
      • Pull the ribbon connector and blade connector through the top case.
      Ask FixBot
    1. ACN Iris WG4K Video Camera Replacement, Video Screen Ribbon Cable: step 17, image 1 of 1
      • Note that the video screen is no longer attached to the top case, place in on a flat surface.
      • Gently lift of the silver casing.
      Ask FixBot
    2. ACN Iris WG4K Video Camera Replacement: step 18, image 1 of 3 ACN Iris WG4K Video Camera Replacement: step 18, image 2 of 3 ACN Iris WG4K Video Camera Replacement: step 18, image 3 of 3
      • The two ribbon connectors are indicated by the red rectangles.
      • Disconnect the two ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
      • Gently pull out the ribbon cables. Gently pull out the ribbon cables.
      Ask FixBot
    1. ACN Iris WG4K Video Camera Replacement, Video Screen: step 19, image 1 of 1
      • Gently lift the video screen out of its case.
      Ask FixBot
    1. ACN Iris WG4K Video Camera Replacement, Video Camera: step 20, image 1 of 3 ACN Iris WG4K Video Camera Replacement, Video Camera: step 20, image 2 of 3 ACN Iris WG4K Video Camera Replacement, Video Camera: step 20, image 3 of 3
      • Flip the video screen over so that the screen itself is face-down on a flat surface to expose the camera.
      • Push up on the two clips located on the right and left side of the video camera simultaneously.
      • Gently pull the camera out.
      Ask FixBot
Itze Kenney
1,066 Reputation
9 Guides authored
USF Tampa, Team 20-4, Remmell Spring 2017 Member of USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 73
All Time: 590
