ACN Iris WG4K Lower Case Replacement
  1. ACN Iris WG4K Lower Case Replacement, Handset: step 1, image 1 of 2 ACN Iris WG4K Lower Case Replacement, Handset: step 1, image 2 of 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
    Ask FixBot
  2. ACN Iris WG4K Lower Case Replacement, Lower Case: step 2, image 1 of 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
    Ask FixBot
  3. ACN Iris WG4K Lower Case Replacement: step 3, image 1 of 2 ACN Iris WG4K Lower Case Replacement: step 3, image 2 of 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
    Ask FixBot
  4. ACN Iris WG4K Lower Case Replacement: step 4, image 1 of 3 ACN Iris WG4K Lower Case Replacement: step 4, image 2 of 3 ACN Iris WG4K Lower Case Replacement: step 4, image 3 of 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
    Ask FixBot
  5. ACN Iris WG4K Lower Case Replacement: step 5, image 1 of 2 ACN Iris WG4K Lower Case Replacement: step 5, image 2 of 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
    Ask FixBot
  6. ACN Iris WG4K Lower Case Replacement: step 6, image 1 of 1
    • Gently lift up the lower case to separate it from the top case.
    Ask FixBot
Itze Kenney
1,066 Reputation
9 Guides authored
USF Tampa, Team 20-4, Remmell Spring 2017 Member of USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Members
30 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 446
