ACER Aspire V5-571P-6609 RAM Replacement
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: step 1, image 1 of 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: step 1, image 2 of 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: step 1, image 3 of 3
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
    Ask FixBot
  2. ACER Aspire V5-571P-6609 RAM Replacement: step 2, image 1 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 2, image 2 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 2, image 3 of 3
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
    Ask FixBot
  3. ACER Aspire V5-571P-6609 RAM Replacement: step 3, image 1 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 3, image 2 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 3, image 3 of 3
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
    Ask FixBot
  4. ACER Aspire V5-571P-6609 RAM Replacement: step 4, image 1 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 4, image 2 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 4, image 3 of 3
    • Repeat the same process from the previous step for the second slot.
    Ask FixBot
  5. ACER Aspire V5-571P-6609 RAM Replacement: step 5, image 1 of 2 ACER Aspire V5-571P-6609 RAM Replacement: step 5, image 2 of 2
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
    Ask FixBot
  6. ACER Aspire V5-571P-6609 RAM Replacement: step 6, image 1 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 6, image 2 of 3 ACER Aspire V5-571P-6609 RAM Replacement: step 6, image 3 of 3
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order with new RAM cards.
Ernesto Pacheco
277 Reputation
2 Guides authored
Gateway, Team 1-1, Pee Fall 2022 Member of Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 46
All Time: 470
