ABXY/D-pad Conductive Sticker Replacement
    1. ABXY/D-pad Conductive Sticker Replacement, Prepare for disassembly: step 1, image 1 of 1
      • Before you begin, power off the console and remove:
      • The stylus
      • Any game cartridge
      • The microSD card
      Ask FixBot
    2. ABXY/D-pad Conductive Sticker Replacement, Remove the back cover screws: step 2, image 1 of 1
      • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
      Ask FixBot
    3. ABXY/D-pad Conductive Sticker Replacement, Release the back cover clips: step 3, image 1 of 2 ABXY/D-pad Conductive Sticker Replacement, Release the back cover clips: step 3, image 2 of 2
      • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
      • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
      Ask FixBot
    4. ABXY/D-pad Conductive Sticker Replacement, Disconnect the back cover: step 4, image 1 of 3 ABXY/D-pad Conductive Sticker Replacement, Disconnect the back cover: step 4, image 2 of 3 ABXY/D-pad Conductive Sticker Replacement, Disconnect the back cover: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
      • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
      Ask FixBot
    5. ABXY/D-pad Conductive Sticker Replacement, Battery Removal: step 5, image 1 of 2 ABXY/D-pad Conductive Sticker Replacement, Battery Removal: step 5, image 2 of 2
      • The battery is lightly adhered to its enclosure.
      • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
      Ask FixBot
    1. ABXY/D-pad Conductive Sticker Replacement, Motherboard: step 6, image 1 of 2 ABXY/D-pad Conductive Sticker Replacement, Motherboard: step 6, image 2 of 2
      Buy
      • There are 8 ribbon cables that need to be removed as shown in the picture.
      • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently flat in the arrow direction. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
      • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
      • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
      Ask FixBot
    2. ABXY/D-pad Conductive Sticker Replacement: step 7, image 1 of 2 ABXY/D-pad Conductive Sticker Replacement: step 7, image 2 of 2
      • Unplug the following wires from the motherboard using a pair of tweezers.
      Ask FixBot
    3. ABXY/D-pad Conductive Sticker Replacement: step 8, image 1 of 2 ABXY/D-pad Conductive Sticker Replacement: step 8, image 2 of 2
      • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
      • Remove the motherboard from the device.
      Ask FixBot
    1. ABXY/D-pad Conductive Sticker Replacement, ABXY/D-pad Conductive Sticker: step 9, image 1 of 1
      • Flip the board over so the cartridge slot is on the bottom
      • Peel off the damaged sticker and replace it with the new one
      • ABXY buttons
      • D-pad
      • If the new sticker doesn't fit properly, you can cut it apart and stick each pad down separately. As long as they're properly aligned and secure, the buttons will still work normally
      Ask FixBot
2 other people completed this guide.
darth mango
3,823 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 230
All Time: 5,810
