AARP RealPad MA7BX2 Motherboard Replacement
    1. AARP RealPad MA7BX2 Motherboard Replacement, Back Cover: step 1, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement, Back Cover: step 1, image 2 of 2
      • Loosen the back cover using the suction cup.
      • Pull up on the center of the back with the suction cup.
      • Pull up on all four corners of the back with the suction cup.
      Ask FixBot
    2. AARP RealPad MA7BX2 Motherboard Replacement: step 2, image 1 of 1
      • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
      • Slide the opening tool around the edges of the device.
      • Wedge it open using the opening tool.
      • Use the suction cup again if you're having trouble removing the back cover.
      Ask FixBot
    3. AARP RealPad MA7BX2 Motherboard Replacement: step 3, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 3, image 2 of 2
      • The black tape is stuck to delicate wires; remove with caution.
      • Peel off the silver tape.
      • Gently pull off the black tape.
      Ask FixBot
    4. AARP RealPad MA7BX2 Motherboard Replacement: step 4, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 4, image 2 of 2
      • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
      Ask FixBot
    5. AARP RealPad MA7BX2 Motherboard Replacement: step 5, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 5, image 2 of 2
      • Lift off the black audio cover.
      Ask FixBot
    1. AARP RealPad MA7BX2 Motherboard Replacement, Motherboard: step 6, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Remove the two JIS #000 screws.
      Ask FixBot
    2. AARP RealPad MA7BX2 Motherboard Replacement: step 7, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 7, image 2 of 2
      • Flip up the small black connectors using a spudger or your nails.
      • Be careful when flipping them up. Too much force can cause them to break.
      Ask FixBot
    3. AARP RealPad MA7BX2 Motherboard Replacement: step 8, image 1 of 1
      • Remove battery.
      • Removing the battery may need some force. Be careful as to not break anything.
      Ask FixBot
    4. AARP RealPad MA7BX2 Motherboard Replacement: step 9, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to loosen up the sides of speakers by going into the gaps, before picking it up.
      • There are magnets holding down the speakers. Be careful as to not pick them up with the speakers.
      • The top of the speakers are very fragile and may fall out at the slightest touch. Be careful when picking them up.
      Ask FixBot
    5. AARP RealPad MA7BX2 Motherboard Replacement: step 10, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 10, image 2 of 2
      • Remove all wire connections by sliding them out of the connectors.
      • Be careful as to not forcefully pull out anything because the wires are very delicate.
      Ask FixBot
    6. AARP RealPad MA7BX2 Motherboard Replacement: step 11, image 1 of 1
      • Take off the motherboard and set it aside. Your Finished product should look like this.
      Ask FixBot
1 Guide Comment
I have a realpad that's is missing all the motherboard and do y'all know where can I take to get it fix because I got it for my sweet 15 as a gift from my uncle and aunt
Luz Hernandez - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 908
