AARP RealPad MA7BX2 Back Cover Replacement
    1. AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: step 1, image 1 of 2 AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Loosen the back cover using the suction cup.
      • Pull up on the center of the back with the suction cup.
      • Pull up on all four corners of the back with the suction cup.
      Ask FixBot
    2. AARP RealPad MA7BX2 Back Cover Replacement: step 2, image 1 of 1
      • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
      • Slide the opening tool around the edges of the device.
      • Wedge it open using the opening tool.
      • Use the suction cup again if you're having trouble removing the back cover.
      Ask FixBot
    3. AARP RealPad MA7BX2 Back Cover Replacement: step 3, image 1 of 2 AARP RealPad MA7BX2 Back Cover Replacement: step 3, image 2 of 2
      • The black tape is stuck to delicate wires; remove with caution.
      • Peel off the silver tape.
      • Gently pull off the black tape.
      Ask FixBot
    4. AARP RealPad MA7BX2 Back Cover Replacement: step 4, image 1 of 2 AARP RealPad MA7BX2 Back Cover Replacement: step 4, image 2 of 2
      • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
      Ask FixBot
    5. AARP RealPad MA7BX2 Back Cover Replacement: step 5, image 1 of 2 AARP RealPad MA7BX2 Back Cover Replacement: step 5, image 2 of 2
      • Lift off the black audio cover.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 41
All Time: 1,221
