This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Another model of a 9V battery tester, in this case using 2 LED diodes and 3 standard rectifier diodes; personally, I like the other 2 testers better, but this one works too.
View of the design and simple electrical schematic; the improved design includes a discharge resistor between the battery terminals.
1 Resistance of 6800 ohms 1/4W or 1/2W, 2 Red 5 mm LEDs, 3 1N4007 rectifier diodes, 1 9V battery clip, quick-drying 2-component glue.
The mounting base is a 9 V battery clip that we will obtain from a 9V battery; it is a great clip that we will use as a base for this assembly.
In the assembly phase, we will perform the soldering between diodes and with the resistance, then soldering the 3 rectifier diodes.
Video with the previous assembly improved by adding a discharge resistance.
Final view before applying the glue; to apply this, we will wrap the 4 sides of the clip with electrical tape and fill the center until all components are completely covered.
END of the Guide:
Other guides in this series: Electronics Skills
2 other people completed this guide.
