8Bitdo N30 Joystick Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
145
All Time:
4,093
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a faulty joystick component on the 8Bitdo N30 Arcade Stick without damaging the Retro game controller.
A Phillips #0 screwdriver and a flathead 3/32” screwdriver are required to remove screws.
No special skills are required. Take caution in regards to removing and organizing the pieces of the 8Bitdo N30 Joystick when you are replacing the joystick.
Tools
    1. 8Bitdo N30 Joystick Replacement, Joystick: step 1, image 1 of 2 8Bitdo N30 Joystick Replacement, Joystick: step 1, image 2 of 2
      • Turn the device over so that the bottom of the device is facing up.
      Ask FixBot
    2. 8Bitdo N30 Joystick Replacement: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to remove all ten of the 3 mm screws on the back plate.
      Ask FixBot
    3. 8Bitdo N30 Joystick Replacement: step 3, image 1 of 2 8Bitdo N30 Joystick Replacement: step 3, image 2 of 2
      • Remove the rubber slider from the device.
      • Hold the arcade stick and pry the back panel away from the device until it comes off.
      • Remember the position of the rubber slider; it will be replaced at the end of the process.
      Ask FixBot
    4. 8Bitdo N30 Joystick Replacement: step 4, image 1 of 2 8Bitdo N30 Joystick Replacement: step 4, image 2 of 2
      • Locate the back piece of the joystick.
      • Remove the four screws that secure the joystick using the Phillips #0 screwdriver.
      Ask FixBot
    5. 8Bitdo N30 Joystick Replacement: step 5, image 1 of 2 8Bitdo N30 Joystick Replacement: step 5, image 2 of 2
      • Use a flathead screwdriver to remove the middle screw that holds the ball piece onto the joystick.
      • Remove the ball piece and set it aside.
      • Be sure to hold the ball piece in place while turning the screw counterclockwise.
      • When attaching the new joystick and ball piece, turn the screw clockwise while holding the ball piece in place.
      Ask FixBot
    6. 8Bitdo N30 Joystick Replacement: step 6, image 1 of 3 8Bitdo N30 Joystick Replacement: step 6, image 2 of 3 8Bitdo N30 Joystick Replacement: step 6, image 3 of 3
      • Locate the joystick wires that are attached to the four plugs on the motherboard and disconnect them.
      • In fine print, "left," "down," "up," and "right" are found above the wires that need to be removed.
      • Take caution and gently disconnect the wires.
      Ask FixBot
    7. 8Bitdo N30 Joystick Replacement: step 7, image 1 of 2 8Bitdo N30 Joystick Replacement: step 7, image 2 of 2
      • Remove the back piece from the mounting plate.
      • Replace the joystick's back piece.
      Ask FixBot
Follow the steps in reverse order to install the new joystick.
Once again, don’t forget the rubber slider for the back panel.
Boot up your favorite PC or Nintendo Switch fighting game and make sure your joystick works!
2 other people completed this guide.
1 Guide Comment
looks just like the mayflash f300
Jon Hernandez - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 145
All Time: 4,093
