Tools
Introduction
Go to step 1 ↓Do you need to replace the D-pad on your 8BitDo Ultimate Wireless? If so, this guide will show you how to correctly and safely do so!
With that said, please make sure to check our Troubleshooting Guides first. Often times, there is no need to go as far as replacing the D-pad entirely.
Before beginning, turn off the controller and ensure it will not accidentally reconnect during the repair.
Insert an opening pick into the seam between the left controller grip and main controller body.
Pry the grip off.
Repeat for the right grip.
Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell, then lift the board out.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
