8BitDo Ultimate Wired Vibration/Rumble Motor Replacement
    1. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: step 1, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: step 1, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: step 1, image 3 of 3
      • Orient the controller such that the back of the controller is facing you.
      • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
      Ask FixBot
    2. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 2, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 2, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 2, image 3 of 3
      • Pry the other grip panel off using the same method.
      Ask FixBot
    3. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 3, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 3, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 3, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm screw on the backside.
      • Use tweezers to help you remove the screw if it does not come out with the driver.
      Ask FixBot
    4. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 4, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 4, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 4, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
      Ask FixBot
    5. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 5, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 5, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 5, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
      Ask FixBot
    6. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 6, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 6, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 6, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
      Ask FixBot
    7. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 7, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 7, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 7, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
      Ask FixBot
    8. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 8, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 8, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 8, image 3 of 3
      • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
      Ask FixBot
    9. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 9, image 1 of 2 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 9, image 2 of 2
      • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
      Ask FixBot
    10. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 10, image 1 of 2 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 10, image 2 of 2
      • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
      • A ribbon cable connects the front and back portions of the controller.
      Ask FixBot
    11. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 11, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 11, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 11, image 3 of 3
      • Pull the midframe free with an adequate amount of force.
      Ask FixBot
    12. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 12, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 12, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 12, image 3 of 3
      • Detach the motor connector from the motherboard.
      Ask FixBot
    13. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 13, image 1 of 2 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 13, image 2 of 2
      • Pull the weight out of the housing with adequate force.
      Ask FixBot
    14. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 14, image 1 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 14, image 2 of 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: step 14, image 3 of 3
      • Remove the rumble or vibration motor from the controller.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 1,106
