8BitDo Ultimate Wired Motherboard Replacement
    1. 8BitDo Ultimate Wired Motherboard Replacement, Motherboard: step 1, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement, Motherboard: step 1, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Orient the controller such that the back of the controller is facing you.
      • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
      Ask FixBot
    2. 8BitDo Ultimate Wired Motherboard Replacement: step 2, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 2, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 2, image 3 of 3
      • Pry the other grip panel off using the same method.
      Ask FixBot
    3. 8BitDo Ultimate Wired Motherboard Replacement: step 3, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 3, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 3, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm torx screw on the backside.
      • Use tweezers to remove the screws (optional).
      Ask FixBot
    4. 8BitDo Ultimate Wired Motherboard Replacement: step 4, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 4, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 4, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
      Ask FixBot
    5. 8BitDo Ultimate Wired Motherboard Replacement: step 5, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 5, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 5, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
      Ask FixBot
    6. 8BitDo Ultimate Wired Motherboard Replacement: step 6, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 6, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 6, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
      Ask FixBot
    7. 8BitDo Ultimate Wired Motherboard Replacement: step 7, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 7, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 7, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
      Ask FixBot
    8. 8BitDo Ultimate Wired Motherboard Replacement: step 8, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 8, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 8, image 3 of 3
      • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
      Ask FixBot
    9. 8BitDo Ultimate Wired Motherboard Replacement: step 9, image 1 of 2 8BitDo Ultimate Wired Motherboard Replacement: step 9, image 2 of 2
      • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
      Ask FixBot
    10. 8BitDo Ultimate Wired Motherboard Replacement: step 10, image 1 of 2 8BitDo Ultimate Wired Motherboard Replacement: step 10, image 2 of 2
      • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
      • A ribbon cable connects the front and back portions of the controller.
      Ask FixBot
    11. 8BitDo Ultimate Wired Motherboard Replacement: step 11, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 11, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 11, image 3 of 3
      • Pull the midframe with an adequate amount of force.
      Ask FixBot
    12. 8BitDo Ultimate Wired Motherboard Replacement: step 12, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 12, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 12, image 3 of 3
      • Gently pull the vibration motor connector out of its socket.
      Ask FixBot
    13. 8BitDo Ultimate Wired Motherboard Replacement: step 13, image 1 of 2 8BitDo Ultimate Wired Motherboard Replacement: step 13, image 2 of 2
      • Pull the weight out of the housing with adequate force.
      Ask FixBot
    14. 8BitDo Ultimate Wired Motherboard Replacement: step 14, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 14, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 14, image 3 of 3
      • Use tweezers to gently unplug the bumper on the right hand side.
      Ask FixBot
    15. 8BitDo Ultimate Wired Motherboard Replacement: step 15, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 15, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 15, image 3 of 3
      • Use tweezers to gently unplug the bumpers on the left hand side.
      Ask FixBot
    16. 8BitDo Ultimate Wired Motherboard Replacement: step 16, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 16, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 16, image 3 of 3
      • Use your fingers to remove the joystick cover on the left hand side with adequate force.
      Ask FixBot
    17. 8BitDo Ultimate Wired Motherboard Replacement: step 17, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 17, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 17, image 3 of 3
      • Use your fingers to remove the joystick cover on the right hand side with adequate force.
      Ask FixBot
    18. 8BitDo Ultimate Wired Motherboard Replacement: step 18, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 18, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 18, image 3 of 3
      • Use an opening tool to pry the motherboard apart from the structure of the controller
      Ask FixBot
    19. 8BitDo Ultimate Wired Motherboard Replacement: step 19, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 19, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 19, image 3 of 3
      • Use a Jimmy to open the small metal bracket (right) on the front side of the motherboard.
      Ask FixBot
    20. 8BitDo Ultimate Wired Motherboard Replacement: step 20, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 20, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 20, image 3 of 3
      • Use a Jimmy to open the small metal bracket (left) on the front side of the motherboard.
      Ask FixBot
    21. 8BitDo Ultimate Wired Motherboard Replacement: step 21, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 21, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 21, image 3 of 3
      • Use tweezers to remove the white strip from the black bracket.
      Ask FixBot
    22. 8BitDo Ultimate Wired Motherboard Replacement: step 22, image 1 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 22, image 2 of 3 8BitDo Ultimate Wired Motherboard Replacement: step 22, image 3 of 3
      • Use your fingers to gently remove the power cord.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 52
All Time: 1,680
