Up to 20% off select tools
8BitDo Ultimate Wired Buttons Replacement
Views: 5K
View statistics:
Past 24 Hours:
10
Past 7 Days:
65
Past 30 Days:
301
All Time:
5,017
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 55 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you need to replace the buttons, you can access them with this guide. You may need to change the buttons if they are worn down, cracked, jammed, or missing. For this guide, you will need a plastic opening tool, Phillips #0 screwdriver, TR6 Torx Security screwdriver, and ESD-safe blunt nose tweezers (optional).
This repair process is not too difficult, but be careful to not damage anything when you take off the top panel. Make sure the controller is not plugged into a power source.
    1. 8BitDo Ultimate Wired Buttons Replacement, Buttons: step 1, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement, Buttons: step 1, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement, Buttons: step 1, image 3 of 3
      • Orient the controller such that the back of the controller is facing you.
      • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
      Ask FixBot
    2. 8BitDo Ultimate Wired Buttons Replacement: step 2, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 2, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 2, image 3 of 3
      • Pry the other grip panel off using the same method.
      Ask FixBot
    3. 8BitDo Ultimate Wired Buttons Replacement: step 3, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 3, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 3, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm torx screw on the backside.
      • Use tweezers to help remove the screws (optional).
      Ask FixBot
    4. 8BitDo Ultimate Wired Buttons Replacement: step 4, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 4, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 4, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
      Ask FixBot
    5. 8BitDo Ultimate Wired Buttons Replacement: step 5, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 5, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 5, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
      Ask FixBot
    6. 8BitDo Ultimate Wired Buttons Replacement: step 6, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 6, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 6, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
      Ask FixBot
    7. 8BitDo Ultimate Wired Buttons Replacement: step 7, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 7, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 7, image 3 of 3
      • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
      Ask FixBot
    8. 8BitDo Ultimate Wired Buttons Replacement: step 8, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 8, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 8, image 3 of 3
      • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
      Ask FixBot
    9. 8BitDo Ultimate Wired Buttons Replacement: step 9, image 1 of 2 8BitDo Ultimate Wired Buttons Replacement: step 9, image 2 of 2
      • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
      Ask FixBot
    10. 8BitDo Ultimate Wired Buttons Replacement: step 10, image 1 of 2 8BitDo Ultimate Wired Buttons Replacement: step 10, image 2 of 2
      • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
      • A ribbon cable connects the front and back portions of the controller.
      Ask FixBot
    11. 8BitDo Ultimate Wired Buttons Replacement: step 11, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 11, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 11, image 3 of 3
      • Use the Phillips #0 Screwdriver to remove all seven 6.14 mm Phillips screws from the button PCB.
      Ask FixBot
    12. 8BitDo Ultimate Wired Buttons Replacement: step 12, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 12, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 12, image 3 of 3
      • Remove the button PCB.
      • Pinch the silicone cover on the buttons to remove it, such that the buttons are exposed.
      Ask FixBot
    13. 8BitDo Ultimate Wired Buttons Replacement: step 13, image 1 of 3 8BitDo Ultimate Wired Buttons Replacement: step 13, image 2 of 3 8BitDo Ultimate Wired Buttons Replacement: step 13, image 3 of 3
      • Simply using the force from your finger, push the button out of the housing.
      • Pull button out.
      Ask FixBot
8 other people completed this guide.
Author
with
Tanvi Verma
791 Reputation
2 Guides authored
2 Guide Comments
From where to purchase spare parts, like buttons?
Mitko - Reply Share
I purchased mine from the official store: https://shop.8bitdo.com/collections/repa...
Zarlin - Reply Share
Past 24 Hours: 10
Past 7 Days: 65
Past 30 Days: 301
All Time: 5,017
