Up to 20% off select tools
8BitDo Pro 2 Trigger Replacement
Views: 1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
53
Past 30 Days:
247
All Time:
1,047
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your 8BitDo Pro 2 controller trigger is unresponsive or not registering pressure correctly, the trigger mechanism may need to be replaced. This guide will walk you through removing and installing the trigger on your controller.
The trigger is responsible for registering pressure input during gameplay, allowing for control in actions such as aiming, braking, or accelerating. Over time, internal wear can affect how smoothly and accurate the trigger functions are.
Before using the guide, try cleaning the area. You should also test the controller on different devices and ensure it is set to the correct input mode, see the troubleshooting page for more information.
This repair will require you to open the controller. Before beginning, make sure to power off your controller.
    1. 8BitDo Pro 2 Trigger Replacement, Battery: step 1, image 1 of 1
      • Flip the 8BitDo Pro 2 controller so that the back side is facing up.
      Ask FixBot
    2. 8BitDo Pro 2 Trigger Replacement: step 2, image 1 of 1
      • Slide the battery cover off to remove it and expose the battery.
      Ask FixBot
    3. 8BitDo Pro 2 Trigger Replacement: step 3, image 1 of 1
      • Use your hands to remove the battery pack from the controller.
      • Do not bend or puncture the battery pack, this can be hazardous.
      Ask FixBot
    1. 8BitDo Pro 2 Trigger Replacement, Controller: step 4, image 1 of 1
      • Using the iFixit blunt tweezers, peel back the top two corners of the sticker located inside the battery compartment.
      Ask FixBot
    2. 8BitDo Pro 2 Trigger Replacement: step 5, image 1 of 1
      • Use a T6 Torx screwdriver to remove the four 5.0 mm screws from the back of the controller.
      Ask FixBot
    3. 8BitDo Pro 2 Trigger Replacement: step 6, image 1 of 3 8BitDo Pro 2 Trigger Replacement: step 6, image 2 of 3 8BitDo Pro 2 Trigger Replacement: step 6, image 3 of 3
      • Insert the iFixit pick into the seam along the edge of the controller and slide it around to release the clips holding it together.
      • Leave opening picks in the space to keep the top and bottom case from reattaching.
      • Use an iFixit tool to carefully pry around the edges of the controller.
      • Once loosened, gently separate the top and bottom of the controller.
      • Do not separate the top and bottom sections, as they are still connected by a ribbon cable.
      Ask FixBot
    4. 8BitDo Pro 2 Trigger Replacement: step 7, image 1 of 2 8BitDo Pro 2 Trigger Replacement: step 7, image 2 of 2
      • Use a spudger to gently push up on alternating sides of the black plastic tab until it clicks up into its unlocked position.
      • Don't push the tab too hard or too far, otherwise it may come completely off the connector.
      • Use tweezers to gently pull the cable out of its socket.
      • The cable should be able to slide in and out of the socket with little to no force. If you feel resistance, the tab may not be fully unlocked.
      • During reassembly, insert the cable into its socket and use the flat end of a spudger to push the tab down into its locked position.
      • Separate the top and bottom casing of the controller.
      • If you feel resistance, check for any cables still connecting the two halves and avoid forcing them apart.
      Ask FixBot
    1. 8BitDo Pro 2 Trigger Replacement, Trigger: step 8, image 1 of 2 8BitDo Pro 2 Trigger Replacement, Trigger: step 8, image 2 of 2
      • In the back shell, near the trigger assembly, use a finger to hold the small metal spring in place while removing the trigger cap.
      • This will prevent the spring from popping out and getting lost.
      • Use a spudger or opening tool to gently squeeze the two plastic locking hooks on the inside of the trigger cap.
      • Push the trigger cap outward through its slot until it pops free.
      • You may hear a click as the trigger disconnects.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Paige Lucas
643 Reputation
5 Guides authored
1 Guide Comment
I don't recommend fixing the 8bitdo pro 2. I tried to open the case - it was extremely difficult to open. It was hard to align the controller button when I put it back together, and the worst thing is when I tried to reopen the case to realign the button, the PCB and its ribbon just...cracked...rendering the whole thing unusable. So do not open this controller just because you want to replace a button because the PCB breaks so easily!!!!
Mikayla Moussaka - Reply Share
Past 24 Hours: 8
Past 7 Days: 53
Past 30 Days: 247
All Time: 1,047
