8BitDo M30 Gamepad D-Pad Replacement
    1. 8BitDo M30 Gamepad D-Pad Replacement, Unscrew the Back Panel: step 1, image 1 of 2 8BitDo M30 Gamepad D-Pad Replacement, Unscrew the Back Panel: step 1, image 2 of 2
      • Place the controller face down so you can see the back panel.
      • Remove the five T6 Torx screws holding the back panel in place.
      Ask FixBot
    2. 8BitDo M30 Gamepad D-Pad Replacement, Remove the Back Panel: step 2, image 1 of 3 8BitDo M30 Gamepad D-Pad Replacement, Remove the Back Panel: step 2, image 2 of 3 8BitDo M30 Gamepad D-Pad Replacement, Remove the Back Panel: step 2, image 3 of 3
      • Apply lever force on the upper part of the case behind the L button using an opening tool. Make sure to pry towards the back plate. Repeat the step with the R button.
      • After the hooks on the upper left and right side of the controller have come loose, the back panel can be lifted carefully to open up the remaining hooks on the bottom.
      • All in all, the back plate is connected to the front by eight hooks spread across the sides and the bottom of the plate.
      Ask FixBot
    3. 8BitDo M30 Gamepad D-Pad Replacement, Lift up the Circuit Board: step 3, image 1 of 2 8BitDo M30 Gamepad D-Pad Replacement, Lift up the Circuit Board: step 3, image 2 of 2
      • The circuit board is not screwed in and can be taken out by moving it towards the bottom of the controller.
      • Loosen the bumper daughterboards first to reduce the risk of damaging the connecting cables when removing the circuit board.
      Ask FixBot
    4. 8BitDo M30 Gamepad D-Pad Replacement, Remove the Conductive Rubber: step 4, image 1 of 2 8BitDo M30 Gamepad D-Pad Replacement, Remove the Conductive Rubber: step 4, image 2 of 2
      • Raise the conductive rubber above the D-Pad, slide it to the side and remove it.
      Ask FixBot
    5. 8BitDo M30 Gamepad D-Pad Replacement, Remove the D-Pad: step 5, image 1 of 3 8BitDo M30 Gamepad D-Pad Replacement, Remove the D-Pad: step 5, image 2 of 3 8BitDo M30 Gamepad D-Pad Replacement, Remove the D-Pad: step 5, image 3 of 3
      • Use a spudger to apply pressure to the circular opening of the D-Pad to detach it from the plastic part that secures it.
      • The two parts of the D-Pad are held together by a clip-on mechanism.
      • Now you can replace the D-Pad itself or clean it before applying new lubricant.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure to not screw the T6 Torx screws in too tight as this may cause you to strip them out, as reddit user u/Gwennifer points out in this thread.
Manuel Haeussermann
491 Reputation
2 Guides authored
2 Guide Comments
I would like to know where I can find rubber membranes for the M30 controller, both for the down arrow of my D-pad and the A button are worn out.
Jonas SLC - Reply Share
Second that. 8BitDo does not look like they carry M30 parts. They catered more to the big N.
Karcus - Reply Share
Past 24 Hours: 13
Past 7 Days: 45
Past 30 Days: 431
All Time: 6,814
