Up to 20% off select tools
6. Installing Klipper Screen
Views: 2.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
100
All Time:
2,504
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide I will show you how to setup Klipper screen on a Big Tree Tech PiTFT50 screen.
    1. 6. Installing Klipper Screen, 6. Installing Klipper Screen: step 1, image 1 of 1
      • You need to set the OS to boot to console
      • sudo raspi-config
      • 1 System Options > S5 Boot / Auto Login > B1 Console. Then reboot
      • Download and install KlipperScreen
      • git clone https://github.com/jordanruthe/KlipperSc...
      • cd ~/KlipperScreen
      • ./scripts/KlipperScreen-install.sh
      • When the install is finished reboot the RPI. This will take some time to install so feel free to get yourself a cold beverage and relax for a little bit.
      Ask FixBot
    2. 6. Installing Klipper Screen: step 2, image 1 of 1
      • If you loaded my config files it should already be included but check moonraker.conf contains:
      • [authorization] under trusted clients contains 127.0.0.1
      • [update manager KlipperScreen]
      Ask FixBot
    3. 6. Installing Klipper Screen: step 3, image 1 of 2 6. Installing Klipper Screen: step 3, image 2 of 2
      • If you used the latest version of Mainsail(v7.0) skip this next command.
      • git clone https://github.com/mainsail-crew/moonrak...
      • Regardless if you used the latest version or not run
      • bash ~/moonraker-timelapse/install.sh
      • Make sure printer.cfg calls the timelapse config
      • [include timelapse.cfg]
      • Make sure the [timelapse] section is uncommented in moonraker.conf
      Ask FixBot
Finish Line
Author
with
David Husolo
9,382 Reputation
33 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 100
All Time: 2,504
