Up to 20% off select tools
5. Canbus
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
78
All Time:
1,588
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
5. Canbus
Introduction
Go to step 1 ↓
Do not connect 24v until told to do so. It's also wise to disconnect the hotend heater because some versions of the CAN board had the heater pins tied to the bootloader pin. It can cause the hotend to start heating uncontrollably.
    1. 5. Canbus, 5. Canbus: step 1, image 1 of 1
      • Create the CAN0 interface file
      • sudo nano /etc/network/interfaces.d/can0
      • Enter the following
      • auto can0 iface can0 can static bitrate 500000 up ifconfig $IFACE txqueuelen 256 pre-up ip link set can0 type can bitrate 500000 pre-up ip link set can0 txqueuelen 256
      • You can copy paste into the file but make sure your formatting is correct to include the single space in the beginning of the last 4 lines.
      • Exit and save the file with CTRL + SHIFT X > Yes
      • Sudo Reboot
      Ask FixBot
    2. 5. Canbus: step 2, image 1 of 2 5. Canbus: step 2, image 2 of 2
      • The CAN board needs a bootloader so we can flash the Klipper firmware. We will use CanBoot. Download the CanBoot repository:
      • git clone https://github.com/Arksine/CanBoot
      • cd CanBoot
      • make clean
      • make menuconfig
      Ask FixBot
    3. 5. Canbus, EBB36 v1.0: step 3, image 1 of 1
      • Micro-controller Architecture > (STMicroelectronics STM32)
      • Processer model > STM32F072
      • Build CanBoot Deployment Application > (Do not build)
      • Bootloader offset > (8KiB bootloader)
      • Clock Reference > (8 MHz)
      • (500000) CAN bus speed
      • Communication interface > (CAN bus (on PB8/PB9))
      Ask FixBot
    4. 5. Canbus, EBB36 v1.2: step 4, image 1 of 1
      • Processer model > STM32G0B1
      • Communication interface > (CAN bus (on PB0/PB1))
      • Application start offset > (8KiB offset)
      Ask FixBot
    5. 5. Canbus: step 5, image 1 of 2 5. Canbus: step 5, image 2 of 2
      • Add the 5v jumper. Connect the USB-C from the Pi to the EBB36 board.
      • Put the EBB36 into DFU mode
      • Press and hold the RESET + BOOT button. Release the RESET button while holding the BOOT button, than release the BOOT button.
      • Get the device ID of the board after it's in DFU mode
      • Before DFU mode
      • In DFU mode
      Ask FixBot
    6. 5. Canbus: step 6, image 1 of 2 5. Canbus: step 6, image 2 of 2
      • Erase and flash the firmware
      • sudo dfu-util -a 0 -D ~/CanBoot/out/canboot.bin --dfuse-address 0x08000000:force:mass-erase:leave -d DEVICE:ID
      • Power off the system. Plug in the 4 wire CAN cable from the UT0C to the EBB36, and power on the the printer and RPI.
      • After the system is powered up verify the CAN network is up.
      • cd klipper
      • python3 lib/canboot/flash_can.py -q
      • You should see 1 entry for application CanBoot. Note your UUID.
      Ask FixBot
    7. 5. Canbus: step 7, image 1 of 1
      • Run
      • cd ~/klipper
      • make menuconfig
      • Select the following
      • Enable extra low-level configuration
      Ask FixBot
    8. 5. Canbus: step 8, image 1 of 1
      • continued:
      • Save the configuration pressing ESC > Yes
      • Run
      • make clean
      • make
      Ask FixBot
    9. 5. Canbus, EBB36 v1.2: step 9, image 1 of 1
      Ask FixBot
    10. 5. Canbus: step 10, image 1 of 3 5. Canbus: step 10, image 2 of 3 5. Canbus: step 10, image 3 of 3
      • flash the EBB36 with the newly compiled firmware
      • python3 ~/CanBoot/scripts/flash_can.py -i can0 -f ~/klipper/out/klipper.bin -u 9fd4db4bdbc0
      • sudo dfu-util -a 0 -d 0483:df11 --dfuse-address 0x08000000 -D ~/CanBoot/out/canboot.bin
      • If all goes well your CAN board should now be flashed
      • run
      • ~/klippy-env/bin/python ~/klipper/scripts/canbus_query.py can0
      • Load the provided files to the printer and press FIRMWARE_RESTART
      • Checking the Machine tab you should see the 4 systems
      Ask FixBot
Finish Line
Author
with
David Husolo
9,382 Reputation
33 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 78
All Time: 1,588
