Up to 20% off select tools
5 Tips & Tricks
Views: 21K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
115
All Time:
21,205
Comments: 1
1 guide comment.
Go to guide comments
Completed: 46
46 people have marked this guide "completed." Will you be next?
Favorites: 22
22 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Community-Contributed Guide
5 Tips & Tricks
Introduction
Go to step 1 ↓
Secret Codes - one of the most important uses of these codes are to get information about your products and troubleshoot common problems.
Hidden Test Menu - lets you troubleshoot hardware issues and check your phone's functionality.
Safe Mode - If your device hang, freezes randomly, restarts, become slow over time, battery drain so quickly and any other issue then you can boot your device into the safe mode. In this mode the OS temporally turns off all user-installed apps.
Developer options - give you access to ADB settings, USB debugging, and various monitoring tools for your device. It's also the one of the first steps to rooting your device.
Screenshot - If you want to shar your home screen with friends
Video Overview
    1. 5 Tips & Tricks, SECRET CODES: step 1, image 1 of 3 5 Tips & Tricks, SECRET CODES: step 1, image 2 of 3 5 Tips & Tricks, SECRET CODES: step 1, image 3 of 3
      • Enter the code from the phone dialer app:
      • *#06# -IMEI number
      • *#1234# - firmware version
      • *#0228# - battery info
      Ask FixBot
    2. 5 Tips & Tricks, HIDDEN TEST MENU: step 2, image 1 of 3 5 Tips & Tricks, HIDDEN TEST MENU: step 2, image 2 of 3 5 Tips & Tricks, HIDDEN TEST MENU: step 2, image 3 of 3
      • Use this code *#0*# to enter the phone into the test menu.
      • From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on.
      Ask FixBot
    3. 5 Tips & Tricks, SAFE MODE: step 3, image 1 of 3 5 Tips & Tricks, SAFE MODE: step 3, image 2 of 3 5 Tips & Tricks, SAFE MODE: step 3, image 3 of 3
      • Switch off the phone.
      • Press and holdthe Volume Down and the Power buttons.
      • When you see the Galaxy logo, release only the Power button
      • Now all third-party apps (apps that are installed by you) are disabled.
      • To exit Safe mode just tap on the Safe mode notification or restart the device manually.
      Ask FixBot
    4. 5 Tips & Tricks, DEVELOPER OPTIONS: step 4, image 1 of 3 5 Tips & Tricks, DEVELOPER OPTIONS: step 4, image 2 of 3 5 Tips & Tricks, DEVELOPER OPTIONS: step 4, image 3 of 3
      • Go to >Menu >Settings >About device, Scroll down to Build number, and tap it seven times.
      • Do not change the options if you do not know what you're doing.
      Ask FixBot
    5. 5 Tips & Tricks, SNAPSHOT: step 5, image 1 of 2 5 Tips & Tricks, SNAPSHOT: step 5, image 2 of 2
      • Press the Power and Home buttons at the same time until a shutter sound is heard or you see a visual indicating a picture was taken.
      • That's all. Did you like this guide?
      Ask FixBot
46 other people completed this guide.
Author
with
ZFix
197,930 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
1 Guide Comment
How to put mobile internet speed can you have sample code?
Richad Paker - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 115
All Time: 21,205
