Up to 20% off select tools
4Sight 9 Cover Replacement
Views: 1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
16
All Time:
1,050
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 3 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Introduction
Go to step 1 ↓
To remove the cover of the tablet you will need a plastic prying tool and 1mm Phillips Screwdriver. Be sure to allot roughly 2-3 minutes for the process. If you don't have a plastic prying tool, your fingers should suffice.
    1. 4Sight 9 Cover Replacement, Cover: step 1, image 1 of 2 4Sight 9 Cover Replacement, Cover: step 1, image 2 of 2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Ask FixBot
    2. 4Sight 9 Cover Replacement: step 2, image 1 of 1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Ask FixBot
    3. 4Sight 9 Cover Replacement: step 3, image 1 of 2 4Sight 9 Cover Replacement: step 3, image 2 of 2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Ask FixBot
3 other people completed this guide.
Author
with
Hali Ramirez
657 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 1,050
