Up to 20% off select tools
4Sight 9 Charging Port Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,885
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
    1. 4Sight 9 Charging Port Replacement, Cover: step 1, image 1 of 2 4Sight 9 Charging Port Replacement, Cover: step 1, image 2 of 2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Ask FixBot
    2. 4Sight 9 Charging Port Replacement: step 2, image 1 of 1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Ask FixBot
    3. 4Sight 9 Charging Port Replacement: step 3, image 1 of 2 4Sight 9 Charging Port Replacement: step 3, image 2 of 2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Ask FixBot
    1. 4Sight 9 Charging Port Replacement, Motherboard: step 4, image 1 of 1
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Ask FixBot
    2. 4Sight 9 Charging Port Replacement: step 5, image 1 of 2 4Sight 9 Charging Port Replacement: step 5, image 2 of 2
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
      Ask FixBot
    3. 4Sight 9 Charging Port Replacement: step 6, image 1 of 2 4Sight 9 Charging Port Replacement: step 6, image 2 of 2
      • Remove the second electrical ribbon from the motherboard.
      • Use the technique for the previous ribbon.
      Ask FixBot
    4. 4Sight 9 Charging Port Replacement: step 7, image 1 of 1
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
      Ask FixBot
    5. 4Sight 9 Charging Port Replacement: step 8, image 1 of 2 4Sight 9 Charging Port Replacement: step 8, image 2 of 2
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
      Ask FixBot
    6. 4Sight 9 Charging Port Replacement: step 9, image 1 of 1
      • Using your fingers, gently lift the motherboard.
      Ask FixBot
    1. 4Sight 9 Charging Port Replacement, Charging Port: step 10, image 1 of 1
      Tool used on this step:
      Buy
      • Use soldering gun and when solder is malleable, lift up on the left side of the charge port until it is not connected to the board with tweezers.
      • Charging port may be very hot due to soldering iron.
      • Repeat this step on right side of charging port.
      Ask FixBot
Author
with
Robert Shredow
185 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,885
