Up to 20% off select tools
4Sight 9 Battery Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
88
All Time:
2,520
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery on the 4Sight 9
    1. 4Sight 9 Battery Replacement, Cover: step 1, image 1 of 2 4Sight 9 Battery Replacement, Cover: step 1, image 2 of 2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Ask FixBot
    2. 4Sight 9 Battery Replacement: step 2, image 1 of 1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Ask FixBot
    3. 4Sight 9 Battery Replacement: step 3, image 1 of 2 4Sight 9 Battery Replacement: step 3, image 2 of 2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Ask FixBot
    1. 4Sight 9 Battery Replacement, Battery: step 4, image 1 of 1
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Ask FixBot
    2. 4Sight 9 Battery Replacement: step 5, image 1 of 2 4Sight 9 Battery Replacement: step 5, image 2 of 2
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      Ask FixBot
7 other people completed this guide.
Author
with
Jack Applegate
439 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 88
All Time: 2,520
