Community-Contributed Guide
Introduction
Go to step 1 ↓The Advantech 422TTL is used to convert a TTL signal, into a differential 422 signal. However, when using the recommended power supply, the output on the RS-422 side is absolute garbage due to the cheap switching power supply injecting noise. We were converting PPS.
We fixed this by using a bench top 12VDC power supply for nice clean power. This guide will document that modification.
Remove side sticker (DC Power 12VDC)
Remove hardware (Screws and metal tabs)
Carefully lift 4 tabs (2 per side) to split unit into two halves.
Remove the PCB from housing, examining where the headphone style power adapter attaches.
Desolder and remove the power adapter.
Positive (red) and negative (black) power lines should attach where the socket was removed.
