4-Stroke Small Gas Engine Spark Plug Replacement
    1. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: step 1, image 1 of 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: step 1, image 2 of 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: step 1, image 3 of 3
      • Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
      Ask FixBot
    2. 4-Stroke Small Gas Engine Spark Plug Replacement: step 2, image 1 of 2 4-Stroke Small Gas Engine Spark Plug Replacement: step 2, image 2 of 2
      • Make sure the engine is turned off and cool to the touch before completing this step.
      • Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
      Ask FixBot
    3. 4-Stroke Small Gas Engine Spark Plug Replacement: step 3, image 1 of 3 4-Stroke Small Gas Engine Spark Plug Replacement: step 3, image 2 of 3 4-Stroke Small Gas Engine Spark Plug Replacement: step 3, image 3 of 3
      • Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
      • Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet.
      • Remove the Champion RC12YC Spark Plug from the device.
      Ask FixBot
2 other people completed this guide.
Jack Linchey
280 Reputation
2 Guides authored
Cal Poly, Team S25-G15, Maness Spring 2018 Member of Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 78
All Time: 2,129
